Показано с 41 по 60 из 61
Тема: Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    Перфекционист затейник
    Украина Николаев
    По умолчанию Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    http://www.zaphaudio.com/SB12.3/
    INTRODUCTION
    This is a large floor standing three way system using SB Acoustics drivers. We use the SB29RDC-C000-4 ring radiator dome tweeter, affectionately known as the dimple dome. For the mids, we use a pair of SB15NRXC30-8 5" midwoofers, and finally a SB34NRX75-6 12" woofer to handle the low end. These are all drivers with very high performance at a good price, and the build quality is excellent. The midrange and tweeter are fully tested and reviewed in the comparisons elsewhere on this site, and the 12" woofer test results are posted below.
    Small designs are a dime a dozen, but very large multi-way designs are not so common. I teamed up with Madisound to "go big" in a big way and this project is the result. The world is full of tiny designs that might find their way to a small shelf, hidden between a plant and some books. This is a design for the other end of the home decor spectrum - when a visitor walks into the room, they can*t help but say "holy crap, look at those speakers!"
    There were a couple of directions we could have gone with this selection of drivers. It came down to the decision between front mount and a side mount woofer. Those two layouts require different crossovers so we had to pick one. We decided on the layout that could be described as "classic wide". These are much more than party speakers however. The design is high end throughout and I can*t even fathom how much a system like this might cost in the retail world. If I had to take a guess, I*d say somewhere in the 5 digit range. While this system is still not exactly cheap, DIY brings the cost down to be much more affordable.
    думаю стоит собирать
ID:	68829   Нажмите на изображение для увеличения.
    old chap
    По умолчанию Re: Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    Так это и так давно известно, одиночный саб либо будет гудеть если в угол поставить, либо не будет гудеть но и баса тоже не будет.
    Какие то чудеса у Вас с сабами...
    Завсегдатай Аватар для Yurgen
    Из Замкадья
    Чудес не бывает, обычные комнатные моды. Когда саба два, например по углам - первая мода взаимоуничтожаеться, если четыре вообще отлично, восемь - идеал, почти равномерное звуковое поле и никаких комнатных резонансов.
    old chap
    Недели 3 назад слушал систему из 4-х сабов по углам ,кончилось тем что 2 саба вообще убрали ,а из оставшихся 2-х собрали кластер ( положили друг на друга и удалили из угла),так что вопрос не в количестве сабов ,а в правильном размещении их в пространстве...
    Ростов
    +1 ,у меня и один в комнате хорошо себя чувствует.
    Из Замкадья
    Если в смысле не гудит, так это просто сделать, но видимо у нас разные понятия сабвуфера.
    Ижевск
    Собрал кто нибудь ?
    Можно же один СЧ поставить .
  8. #47
    Липецк
    Собрал кто нибудь ?
    Зачем один СЧ? Один СЧ нужно тогда большего размера. А больший размер с пищалкой хуже состыкуется. Итд. И получатся совсем другие колонки.
    ---------- Добавлено в 14:08 ---------- Предыдущее сообщение в 13:50 ----------
    И гудит тоже не по детски
    С чего бы ей особо гудеть? Это же ЗЯ. И объём у него немаленький
  9. #48
    Частый гость Аватар для Андрей Никитин
    Россия, г. Воронеж
    Цитата Сообщение от INFRA Посмотреть сообщение
    С 12" басовиком надо задумываться о четырёх полосках уже.
    12" до 80гц активная секция, можно уменьшить объем корректором линквица
    8" до 300-800гц пассивная секция, динамик с лёгким диффузором
    5" до 2500- 5000гц , можно купольник например вифа 75
    1" пищалка...
    - Согласен.
    - Логичным развитием данного проекта, по моему, будет превращение его в полное дАполлито: второй басовик (сверху), увеличение объёма (литров по 130 на динамик и ФИ оформление)...
    - Ну, и корпус нужен "позатейливее"...
    А. Никитин.
    Последний раз редактировалось Андрей Никитин; 04.11.2010 в 15:26.
  10. #49
    Украина Николаев
    и шо это будет? бухтелка и только.
  11. #50
    Россия, г. Воронеж
    - Будет, возможно, вот что (см. рис.).
    ...думаю стоит собирать
    - А сами ещё не собирали?
    А. Никитин.
Название:	BR SB Acoustics.jpg
    Последний раз редактировалось Андрей Никитин; 04.11.2010 в 16:33.
  12. #51
    Украина Николаев
    неинтересный импендас так что увы не планирую
  13. #52
    не дом и не улица
    В этих всех конструкциях меня смущает одно - сколько заплатили автору. Вернее даже не сколько, а сам факт оплаты создания конструкции, то есть автор руководствовался не соображениями типа звук получше, динамики подешевле, видок покруче или что там еще народу надо, а чисто делал то что магазин заказал. Вроде в описании этого проэкта Заф говорит что разработка по заказу Мадисаунда. Типо, у нас херовато продаются СБ динамики, давай ка рекламки поддадим. И Троелс, мне кажется, должен у себя поставить на странице дисклаимер, на кого он работает...
  14. #53
    Липецк
    А что, факт оплаты автору что-то меняет? Все промышленные колонки созданы их конструкторами за деньги (зарплату). И о чём это говорит? Или это каким-то образом делает их колонки или колонки Зафа хуже чем они есть? У нас на форуме тоже многие авторы делают акустику из тех головок, которые у них уже есть, а не из самых лучших или оптимально сочетающихся друг с другом. Ни Заф, ни Мэдисаунд не утверждают, что это лучшие в мире колонки. Просто один из огромного множества вариантов конструкции. Нравится - повторяете, нет - делаете что-то другое.
  15. #54
    Brooklyn NY
    не Запх а ЗАФ!
    Эту конкретную АС его я не слышал но слушал парочку других и могу сказать что его разработки сделанны великолепно. Хочется придратся а не кчему.
    С точки зрения оплаты, не знаю, Заф и свои головы продаёт и чужие реккомендует. СБ хорошие динамики выпускает, почему на них кит не сморозить?
    Троля финансирует Джансен и ещё ктото.
    Эту конкретную АС я бы воспроизводить не стал чисто из эстетических соображений. Гроб на колёсах какойто. Хотя из репутации разработчика, звучать должно здорого. Только менять ничего не надо. Всё уже прощитанно, промеренно и проверенно.
  16. #55
    Россия, г. Воронеж
    Цитата Сообщение от Roman Erlikh Посмотреть сообщение
    ...Только менять ничего не надо. Всё уже просчитано, промерено и проверено.
    - Не сомневаюсь, что "посчитано и проверено". Но, вот только строить АС на "12"-х басовиках со срезом 37 Гц по -3дБ, по моему, несколько несуразно, в принципе...
    - В данном случае ЗЯ, опять же по моему, сделан только ради "безопасности повторяющих".
    А. Никитин.
  17. #56
    Украина Николаев
    с троелзом все проще он работает при поддержке JA а они производят всего 5 динов. из них только на одном у него есть киты и это дин который разрабатывал он сам
  18. #57
    EU
    Хотел замахнуться на что-нибудь типа этого (уж больно мне звучание старых Авалонов понравилось с этим средником и двумя 8")
    http://www.troelsgravesen.dk/mark21.htm
    А на Хай-Фай ру мне сказали что жуткий импульс, ужасная переходная характеристика...
  19. #58
    Частый гость Аватар для SanSound
    По мне, так главный недостаток этих АС - несуразный внешний вид, звучит она, скорее всего, очень достойно. А чего-бы ей не звучать при хороших динамиках, правильном расчете и таких размерах! А жуткость импульса и ужасность переходной хар-ки может смутить только утром 1 января Ну а внешний вид можно подкорректировать художественным оформлением или сеткой в рамке...
  20. #59
    А как они определили про жуткость импульса?
    По мне, так кроме любимой пищалки Троелса, набор динамиков хорош.
    А мне вид вполне нравится.
    Хочется все время такое сделать - с двумя восьмерками и 15М...
    Георгий Крылов
  21. #60
    EU
    А как они определили про жуткость импульса?Я
    Я вообще не знаю что это такое - но Вадим Шлемский с Nag-ом где-то её увидели...
    Мне тоже нравится, Георгий, сделаете такие - возьму первый
