Страница 1 из 3 123 Последняя
Показано с 1 по 20 из 41
Тема: DAC and chips compared --- help needed in Russian translation to English
    Зарегистрировался
    Аватар для philipsmarantz
    California, USA
    По умолчанию DAC and chips compared --- help needed in Russian translation to English
    Hi!
    I was looking at this page which compares DAC and other digital audio chips:
    http://www.soundbsessive.com/informa...out-dac-chips/
    It was sourced from an original Russian website that no longer exists:
    http://vasiltech.nm.ru
    Some records do exist in Archive.
    https://web.archive.org/web/20130514...s/DAC-Bits.txt
    In any case, it is good source but some words are not translated well. What do these words mean (in English)
    odnobitnik
    odnobitnikom
    Sonevskih odnobitnikov
    Thanks!
    По умолчанию Re: DAC and chips compared --- help needed in Russian translation to English
    odnobitnik - "1-bit dac"
    odnobitnikom - "by 1-bit dac"
    Sonevskih odnobitnikov - "Sony*s 1-bit dacs".
    Very controversial table, and not correct in many ways....
    Астрахань
    del
    уже ответили
    хотя дополню
    1-bit dac = Sigma-delta DAC/ADC
    https://ccrma.stanford.edu/~dattorro/BobAdamsAD1879.pdf
    Указ Петра I от 09.12.1709:
    No, sigma-delta is not the number of bits, but the principle of operation.
    It can be either 1-bit or multi-bit.
    P.S. See the page 14 of your pdf
    Астрахань
    I know this, but usually 1 bit is meant as sigma-delta. Sigma-delta can be multi-bit, but it does not have to be. TDA1547 & older, 1bit?
    2 philipsmarantz
    See https://radio-hobby.org/uploads/data...1/pcm1794a.pdf
    Page 24 THEORY OF OPERATION
    It was a long time ago, now 1-bits are not manufactured.
    Астрахань
    Ofcose, cheers
    Завсегдатай Аватар для Оллема
    Ижевск
    А можно я сюда на своем русском влезу?
    Если не затруднит, в целях самообразования, можете пояснить что есть многобитная дельта-сигма? Однобитная, как я понимаю, это просто ШИМ (дифференциальный на выходе ЦАП), а что представляет многобитный выход дельта-сигма ЦАП? Отсчеты, подобные R-2R ЦАП?
    Voronezh
    Это комбинация. Например, 4-х битная матрица в петле дельта-сигмы вместо одного бита.
    Ижевск
    Четырех битная матрица даст 16 уровней... ШИМ с 16-ю уровнями? Или что там на выходе до LP-фильтрации?
    Voronezh
    Дельта-сигма - это не ШИМ. Вы сначала посмотрите как 1-битная Д-С работает, а потом спрашивайте про многобитную. А то так можно с Георга Ома начинать объяснение.
    Ижевск
    Хм... Я дико путаю тип выхода с принципом преобразования, похоже. Ладно, спасибо за пинки время и желание будет - поразбираюсь.
    Если бы ДС было ШИМом, прав был бы известный забаненный тут персонаж-винторазбиратель, со своми "2.7ГГц".
    Астрахань
    А DSD формально шим?
    Нет.
    Астрахань
    ну как-же, изменяется ведь только ширина импульсов.
    No.
    Астрахань
    Я осциллом не смотрел что там идет, по вольному описанию стандарта сужу.
    Ижевск
    "DSD поток - это, по сути вариант цифрового ШИМ сигнала" (с) Андронников
    Непонятно: цифровой ШИМ и аналоговый ШИМ - это что, разное?
    А как еще можно однобитовым сигналом передавать звук, не изменяя ширину импульсов? Изменяем - значит и получаем Широтно-Импульсную Модуляцию.
