Измеритель харакеристик транзиторов
Technical information
- Require Power supply +15VDC/-15VDC (1A )
- Capable to check IV curve both NPN / PNP Power Transistor / Small Transistor
- 8 step Ib 0uA,24uA,48uA,72uA,96uA,120uA,144uA,168uA for small transistor
- 8 step Ib 0.0mA,0.32mA,0.64mA,0.96mA,1.28mA,1.6mA,1.92mA,2.24mA,
- Vce = +10V for NPN and -10V for PNP
- Switching frequency 642Hz
- 2 Jumper to select ranges of Ib and type of transistor { NPN / PNP }
- hole PCB for wiring to external 2 way switches to select ranges of ib and type of transistor
- Require 2 CH Analog or Digital Oscilloscope in x-y mode to connect both CH to this adapter board ( CH1 is X-Axis and CH2 is Y-Axis )
- Comes with the schematic diagram
- Comes with 2 x free BNC BULKHEAD JACK
- PCB size 9.0cm x 10.0cm
---------- Сообщение добавлено 16:45 ---------- Предыдущее сообщение было 16:42 ----------
2SC5171
2SA1930
MJL21194
MJL21193
