Страница 5 из 71 Первая ... 3456715 ... Последняя
Показано с 81 по 100 из 1419
Тема: Еще раз про провода
  1. #81
    Завсегдатай Аватар для 4321
    По умолчанию Re: Еще раз про провода
    Нет не джеки,именно RCA.
    Просто видно фирма инструментальная,потому и гитары.
  2. #82
    Не, они туеву хучу разных коннекторов делают:
    Скрытый текст
    Sort Order:
    Result Count Alphabetical
    Categories sorted by Result Count.
    Standard Circular Connector (5,565)
    XLR Connectors (817)
    Phone Connectors (467)
    DC Power Connectors (246)
    Patch Panels (231)
    Circular Push Pull Connectors (179)
    RCA Phono Connectors (114)
    Modular Connectors / Ethernet Connectors (106)
    Circular DIN Connectors (96)
    USB Connectors (73)
    HDMI, Displayport & DVI Connectors (16)
    RF Connectors / Coaxial Connectors (16)
    Loudspeaker Connectors (15)
    AC Power Entry Modules (10)
    IEEE 1394 Connectors (10)
    Board to Board & Mezzanine Connectors (8)
    Fibre Optic Connectors (8)
    D-Sub High Density Connectors (7)
    D-Sub Adapters & Gender Changers (6)
    RF Adapters - In Series (6)
    Circular Metric Connectors (5)
    Standard Circular Contacts (4)
    D-Sub Dualport Connectors (3)
    Circular MIL Spec Backshells (2)
    Circular MIL Spec Connector (2)
    D-Sub Backshells (2)
    D-Sub Standard Connectors (2)
    D-Sub Tools & Hardware (2)
    Power to the Board (2)
    I/O Connectors (1)
    Terminals (1)
    И не только коннекторов:
    Скрытый текст
    Specialised Cables (1,471)
    Audio Cables / Video Cables / RCA Cables (210)
    DC Power Cords (184)
    Sensor Cables / Actuator Cables (20)
    Wire Labels & Markers (11)
    USB Cables / IEEE 1394 Cables (10)
    Cable Glands, Strain Reliefs & Cord Grips (7)
    Computer Cables (4)
    Conduit Fittings & Accessories (2)
    Heat Shrink Cable Boots & End Caps (2)
    Cable Mounting & Accessories (1)
    Wire Ducting & Raceways (1)
    Crimpers / Crimping Tools (162)
    Extraction, Removal & Insertion Tools (21)
    Other Tools (2)
    Punches & Dies (1)
    Pushbutton Switches (89)
    Slide Switches (40)
    Screws & Fasteners (32)
    Toggle Switches (23)
    Switch Fixings (12)
    Switch Actuators (10)
    Rocker Switches (6)
    I/O Modules (4)
    Knobs & Dials (4)
    Switch Bezels / Switch Caps (4)
    Switch Cases / Switch Covers (3)
    Industrial Panel Mount Indicators / Switch Indicators (1)
    Switch Contact Blocks / Switch Kits (1)
    Audio Modules (1)
    Bluetooth Modules - 802.15.1 (1)
    Interface Development Tools (1)
    Test Plugs & Test Jacks (1)
  3. #83
    Аватар для Ursula
    В своё время попробовал (даже и не вспомню, почему вдруг) следуещее.
    Отдали мне катушку (деревянную, метр в диаметре) с намотанным каким-то синеньким кабелем с витой парой.
    Стал как-то его обжимать по назначению - а он прилично толще (жила по сечению), расстроился(((
    А потом решил вот попробовать аудио из него сделать:
    И межблок делал, и колоночный. В обоих случаях все цветные между собой в параллель, белые - тоже.
    Очень вкусно вышло))) Неудобен лично мне только в одном: он жесткий очень для межблока.
    А колоночный имеет продолжение)))
    Мне задарили пружинные клеммы какие-то нарядные))) В местной аудиолавке.
    Я взял блатную немецкую термоусадку, всё это запаял-заделал и стал предлагать на прослушку: типа новый мега-бренд на российский рынок выходит!
    Жаль, ещё не было всяких стограммов и прочих пидриторов!
    С каким уважением и пафосом удифилы рассматривали, сравнивали и обсуждали ЭТО!
    ЗЫ можем повторить, как грится)))
    Он цел, кстати)
    Ключевые слова "Отдали" и "Мне задарили". Оставшихся денег хватило таки на термоусадку... Нормальный человек, хоть как то связанный с аудио, даже в самом его начале, не то, что слушать, да даже в руки не возьмет кабель по уши запаянный в термоусадку. Если ваши взяли, значит таков ваш круг.
    ---------- Сообщение добавлено 06:15 ---------- Предыдущее сообщение было 06:02 ----------
    Интересна общая тенденция - провода можно ( а то и нужно ) делать из любого дерьма, что под ногами валяется, а вот разъемы почему-то должны быть Cardas или, как минимум, обжимать кабель должны крепко. Дерьмо как ни обожми, оно дерьмом и останется. И, кстати, это большое заблуждение касательно разъемов, что чем туже входит, тем лучше проходит (звук, в смысле, музыка ). Здесь, правда, тоже есть некоторая зависимость, и она не в пользу "закрути разъем посильнее плоскогубцами", а как раз наоборот, но, опять же, ваша система должна позволить вам это "увидеть".
  4. #84
    А вы вообще попали не в свой круг. Тут нормальные люди собрались.
  5. #85
    Аватар для Ursula
    Я сюда попал практически вместе с вами, в 2010-ом году)
  6. #86
    И что? У вас от это мозги появились?
    Опять сказки трахнутого аудиофила.
  7. #87
    Ой как интересно. А можно подробностей? Чем плоха термоусадка, какая именно термоусадка плоха? Намного ли она хуже фторопластовых трубочек, киперной ленты, синей изоленты или чем там аудиофилитики обматывают моножилу третьего рейха?
  8. #88
    Киров
    Цитата Сообщение от ДимычСф Посмотреть сообщение
    сколько доводилось КГХЛ разделывать - ВСЕГДА жилы чёрные.
    Потому, что они в резине - медь и сера быстро реагируют))), НО!! в итоге получается тот самый, многими горячо любимый - литцендрат (с изоляцией каждой жилы)) и этот кабель никогда не "звенит" (на слух) в отличии от луженых и прочих... к чему бы это??)))
    Тогда я использую Хул Революшин.
    Но мне несколько не нравился его расхлябанный бас.
    КМК тут больше сказывается "ретро" воспитание слуха самого Хула)) - бумажные/рупорные динамики требовали некоторого "смягчения" подачи - вот он и делает такие шнурки, и слух у него с возрастом подсаживается - оттуда и стремление "жесть" в сч/вч внести... - это и на его диске слышно
  9. #89
    Давно не заходил
    Voronezh
    Ну как же!? Каждый сантиметр термоусадки на кабеле добавляет примерно один метр опаздывания сигнала по этому кабелю.
    Тока не спрашивайте, что такое "один метр опаздывания" - это дано понимать только достигшим просветления. Короче, Вы не из того круга, где это можно знать! Возможно, momitko знает. Но он не скажет все равно. У них тут замкнутый круг, секта.
  10. #90
    Калуга
    Ursula, спасибо!
    Вы сделали мне день!
    Пойду электронам расскажу - тоже поржут!
  11. #91
    Вы еще расскажите, что он шнурки рассчитывал, а не басни сочинял
  12. #92
    Аватар для Ursula
    Ursula, спасибо!
    Электроны давно уже ржут. С того момента, как вы им приписали св-во электрического тока. Только не надо меня спрашивать, что такое эл. ток, я не знаю. Может Тесла знал.
  13. #93
    Киров
    Сообщение от Борисыч44
    Вы когда цитируете, попробуйте ещё и понять смысл фразы - у него со слухом проблемы, а не "с расчетами"))))
  14. #94
    Россия
    Пил чай с шоколадкой, чуть не подавился
    Ursula, спасибо!
    Весна приближается. Ща начнется.
  15. #95
    Только вакуум или элегаз
  16. #96
    Частый гость Аватар для ДимычСф
    Тульщина
    Хмммм... Не боитесь от владельцев кабелей... Ну... Хотя бы, того же NordOst, по сусалам огрести? )))) Или это некошерные удифилы? ))))
  17. #97
    У самих кулаки имеются, а у черновцев зубы.
    ---------- Сообщение добавлено 22:04 ---------- Предыдущее сообщение было 22:03 ----------
    Кстати, Урсула, вы девочка или мальчик? Или среднего рода?
  18. #98
    лентяй Аватар для владимирр
    Болото.
    "Природа всё делае медленно но вовремя". (С)
  19. #99
    По поводу Революшина,на сколько я знаю,его стали производить с конца 80г.
    Там 6мм жила в центре,по кругу 20 жил литцендрата.
    Используется по одному проводу.
    Потому я и утянул пару в оплётку.
    Сравнивал с Транспарентом Ультра.
    У меня он 15 лет.
    ---------- Сообщение добавлено 00:22 ---------- Предыдущее сообщение было 00:20 ----------
    Да лопатки есть в магазе Электромонтаж.
    8мм
    Хорошие.
  20. #100
    Я забыл ваше фамилие, Доктор Пилюлькин знает, идите в попу с вашими кабельными понтами. Конкретно идите, ибо вагинобол вы конкретный тоже.
