Power handling RMS ................... 1000W
Power handling Music .................. 1600W
Power handling Peak ................... 3200W
Frequency response .................... 35 ÷ 130 Hz
Impedance (nominal f.r.) .............. 8 Ohm
Sensitivity (1W@1m) ................... 101 dB/W/m
Peak SPL (@1m) ......................... 136 dB/m
Continuous SPL (@1m) ............... 128 dB/m
Transducers
LF sub system.............................. 1 x 18” SB001XBT-8
LF sub system SE18/A................. 1 x 18” SB1864-4
Nominal Impedance ..................... 8 Ohm
Input power rating SB001XBT-8 .. 1000W
Continuous program..................... 2000W
Input power rating SB1864-4 ....... 700W
Continuous program..................... 1400W
Calculated Max SPL (@1m)......... 139 dB/m
Physical
Enclosure ..................................... HDSC
Input connectors........................... 2 x NL4FC Speakon
Dimensions (LxHxP) .................... 775 x 575 x 610mm
Weight ......................................... 55kg (64kg SE18/A)
![Нажмите на изображение для увеличения.
