Страница 4 из 11 Первая ... 23456 ... Последняя
Показано с 61 по 80 из 204
Тема: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Перфекционист затейник
    Аватар для cka3o4nuk
    Украина Николаев
    По умолчанию ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    ASUS just released an audio precision report of its latest product Xonar Essence STX. (
    According to ASUS, the yet-to-be-release audio product Xonar Essence STX is “world’s first onboard headphone amp 600ohms headphone with <100dB THD+N”. What’s more, Xonar Essence STX isolated power sources for headphone output and normal audio output. The whole card is using Nichicon capacitors which is called “fine gold”. We don’t know the release date of the card, but it will become another expensive enthusiast audio product.
    Craving for the clearest audio source to support your precious headphone and speakers? Then let Xonar Essence STX amaze you. Being the world’s first audio card to achieve 124dB in signal-to-noise ratio, and capable of driving headphone with highest impedance under lowest 100dB distortion, your only concern will be hard to stop the heavenly music playback from Xonar Essence STX.
    Designed in Essence
    Perfectly sealed by improved EMI shield, Xonar Essence STX’s analog output path generates the purest audio ever from a sound card -124dB signal-to-noise ratio and 0.0003% distortion.
    Fine-selected Components
    With premium-quality digital-to-audio converter and audio-specific capacitors selected, Xonar Essence STX provides <10~90kHZ frequency response and 124dB dynamic range for your unlimited pleasure.
    Shines your beloved headphones
    Drives up to 600ohms headphones with less than 100dB distortion, the built-in headphone amp supports every available headphone in the market with unbelievable audio quality.
  2. #61
    Частый гость Аватар для levgy
    По умолчанию Re: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    ASUS Xonar Essence ST и ASUS Xonar Essence STX - воспроизводит и записывает в режиме 192кГц 24бит
  3. #62
    Частый гость Аватар для Maiden
    Тверь
    http://www.stereophile.com/computera...rds/index.html
    Сам Аткинсон до АСУСа снизашёл
    Александр
  4. #63
    Денег дали просто
  5. #64
    Владивосток
    Я смотрю тут дизайн сменился пока меня небыло! ну ладно я не об этом. Сегодня купил эту карточку. звук отличный что в наушниках, что на акустике!
    Эта карточка стоит почти как мой behringer ultrograph pro fbq6200!
  6. #65
    Новичок Аватар для king_diamond
    Екатеринбург
    В никсах открылась ещё пара возможностей этой карты:
  7. #66
    38RUS
    интересно в сабже три младших бита шумят при записи 24 разряда?
  8. #67
    Здравствуйте. Недавно приобрёл такую карту, только ST, и у меня два вопроса: как поставить дрова asio? и с какими операционниками лучше звук?
  9. #68
    Владивосток
    Скачиваешь программу ASIO4ALL 2.9. Устанавливаешь! Потом скачиваешь плагин к своему плееру! В настройках своего плеера output ставишь asio!
    На счёт звука они все одинаковы, но лично я с ХР не слазию и не слезу!
  10. #69
    Екатеринбург
    Сергей.Е,
    если будете пользоваться плеером foobar2000 то там ASIO4ALL ставить не нужно.Просто установите плагин foo_out_asio.dll
  11. #70
    Екатеринбург
    ...Тут авторитеты пишут, что у этих ЦАПов (которые в Хонаре) нето синтетический , нето пластмассовый звук. Никто не почувствовал?
  12. #71
    Екатеринбург
    ну это смотря с чем сравнивать.Для своей цены я не вижу достойных конкурентов у этой карты.К тому же у нее широкие возможности по модернизированию и улучшению звучания.На хоботе есть ветка посвящённая этому Asus Xonar Essence ST (STX)
  13. #72
    Украина Николаев
    достойный конкурент audiotrack hd2
    а чип в ксонаре - похужее
    there is no going back...
    (c) Tony Gee
  14. #73
    Старый знакомый Аватар для Слава К
    Зачем Вы так шутите? Слабонервные могут не выдержать морального давления и купить...
    С этим ЦАПом, на этой карте, многое зависит от применяемых ОУ... Например, между JRC2114 и THS4062 в I/U данной карты, такая же разница как и между зАпором и каррерой GT...
    Сначала хорошо бы четко определить, а что именно означает "пластмассовость" в звуке? Когда идет речь о фотографии, то это значит, что на изображении замылены мелкие детали и выглядит оно плоским, без объема . Но у данной карты разрешение и сцена на очень высоком уровне (после серьезной модификации)!
    Мне кажется, что более точным будет назвать звучание PCM1792 несколько синтетичным, и только. Если опять обратиться к миру фотографии, то это как пленка и цифра, и у той и у этой, есть свои достоинства и недостатки!
  15. #74
    Украина Николаев
    ну да ксонар чуть хуже а что?
    (c) Tony Gee
  16. #75
    AK4396... В емках он себя "раскрыл" в полной мере...
    А вот на операх, в audiotrak hd2 разработчики не сЪэкономили, в отличии от асуса!
  17. #76
    Челябинск
    "Мутная" достаточно эта Audiotrak.
    С уважением, Игорь.
  18. #77
    Украина Николаев
    простите но проблеми криворокусти креатива к АК и его звуку никакого отношения не имеет
    ---------- Добавлено в 14:16 ---------- Предыдущее сообщение в 14:15 ----------
    не мутнеее асуса с его ядром корявым
    (c) Tony Gee
  19. #78
    Екатеринбург
    Размер ветки сразу отталкивает от этой карты. Всё улучшают и улучшают...
    И похоже одними операционниками не обойтись. TDA1541А хотя бы обгоняет ?
  20. #79
    Екатеринбург
    Всем привет.
    Хочу посоветоваться.
    Сейчас имею карту SB Creative X-Fi Titanium Fatal1ty Champ1on и возникла идея поменять ее на Asus (всегда хочется большего , т.к. в основном использую карту для прослушивания музыки и просмотра кино (усилитель стерео Пионер 407 и колонки AE One) У Креатива очень неудобная разводка - один джек 3,5 на 2 пары колонок, нет RCA и соответственно межблочный шнур не лучшего качества
    Решил подойти к вопросу серьезно и провел тест своей карты RightMark Audio Analyzer 6.2.3 24 бит 96 кГц. и вот что получилось.
    Не подумайте, что я сторонник Креатива - их сервис мягко говоря бесит, драйверы выпускаются 1 раз в год, но полученный результат позволяет усомниться в "лучшести" Asus а
    Какой ваш вердикт ?
  21. #80
    Екатеринбург
    ...не секрет, что Creative, устанавливая на свои звуковые карты дорогие микросхемы ЦАП (цифро-аналоговые преобразователи, DAC), экономит на обвязке, устанавливая дешевые, копеечные ОУ (операционные усилители, вроде JRC4556A) и электролитические конденсаторы...Подробнее тут Доработка звуковых карт Creative
