Страница 1 из 11 123 ... Последняя
Показано с 1 по 20 из 204
Тема: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Перфекционист затейник
    Аватар для cka3o4nuk
    Украина Николаев
    По умолчанию ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    ASUS just released an audio precision report of its latest product Xonar Essence STX. (
    According to ASUS, the yet-to-be-release audio product Xonar Essence STX is “world’s first onboard headphone amp 600ohms headphone with <100dB THD+N”. What’s more, Xonar Essence STX isolated power sources for headphone output and normal audio output. The whole card is using Nichicon capacitors which is called “fine gold”. We don’t know the release date of the card, but it will become another expensive enthusiast audio product.
    Craving for the clearest audio source to support your precious headphone and speakers? Then let Xonar Essence STX amaze you. Being the world’s first audio card to achieve 124dB in signal-to-noise ratio, and capable of driving headphone with highest impedance under lowest 100dB distortion, your only concern will be hard to stop the heavenly music playback from Xonar Essence STX.
    Designed in Essence
    Perfectly sealed by improved EMI shield, Xonar Essence STX’s analog output path generates the purest audio ever from a sound card -124dB signal-to-noise ratio and 0.0003% distortion.
    Fine-selected Components
    With premium-quality digital-to-audio converter and audio-specific capacitors selected, Xonar Essence STX provides <10~90kHZ frequency response and 124dB dynamic range for your unlimited pleasure.
    Shines your beloved headphones
    Drives up to 600ohms headphones with less than 100dB distortion, the built-in headphone amp supports every available headphone in the market with unbelievable audio quality.
    По умолчанию Re: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Похоже, что очень интересный дивайсик выходит, если цену, конечно, не сильно загнут.
    Украина Николаев
    Ламер со стажем, цену обещают около 300
    Частый гость Аватар для Buzzer
    С-Петербург
    Спёрто с хобота
    По данным ASUS, звуковая плата Xonar Essence STX, подготовленная к выпуску этой компанией, станет «первой в мире, оснащенной усилителем для наушников импедансом 600 Ом с уровнем THD+N менее 100 дБ» (0,0003%). Кроме того, компания утверждает, что это первая в мире звуковая плата, имеющая отношение сигнал/шум 124 дБ.
    Схема Xonar Essence STX включает цепи раздельного питания усилителя наушников и усилителя линейного выхода. Элементы платы тщательно экранированы. В конструкции изделия используются конденсаторы Nichicon. Применение «звуковых» конденсаторов и тщательно отобранных компонентов цифро-аналогового преобразователя обеспечивает Xonar Essence STX широкий динамический диапазон и широкий диапазон воспроизводимых частот: он начинается менее чем с 10 Гц и простирается примерно до 90 кГц.
    Дата выпуска карты и ее цена пока не известны, но очевидно, что появления Xonar Essence STX в продаже ждать уже недолго и это будет еще один продукт для состоятельных энтузиастов качественного звука.
    ASUS продолжает выпускать высококачественные звуковые карты, и при этом старается побить собственные рекорды. В новой карте используется высококачественный ЦАП PCM1792A, являющийся на сегодняшний одним самых топовых преобразователей. Для сравнения, популярные профессиональные карты E-MU серии m, горячо любимые аудиофилами за оптимальное цена/качество, и Audiotrak HD2/HD2 Gold используют чуть менее продвинутые ЦАП. В цифрах, это заявленные 124 дБ сигнал/шум для Essence против 120 дБ для E-MU 1212m. Среди устройств с PCM1792A с не заоблачными ценами (до $1000) можно отметить только DAC 5 от Infrasonic. Учитывая то, что Asus явно сделал карту для бюджетного сектора, карта действительно очень интересна.Помимо качественного ЦАП, производитель использует ОУ в кроватках, которые можно менять. Такую возможность ранее предоставляли карты от Auzen, позже Audiotrak в линейке HD2 и Dr.Dac2. В штатной комплектации используются LM4562 и JRC2114.
    Для усиления сигнала для наушников используется TPA612DA2, заявлены высокие характеристики дл 600 Ом, однако более интересны характеристики развиваемой мощности для меньших сопротивлений и уровень искажений. У Xonar D2 к примеру уровень выходной мощности умеренный, не превышающий 1.6 мВт.
    C точки зрения аппаратной начинки все отлично. Некоторые опасения внушает софтовая часть. Так, в первых продуктах Xonar DX и D2 в режиме 44.1 был обнаружен пересчёт данных, и снижение качественных характеристик для этого режима. Безусловно, обнаружить субъективную разницу среди карт топ класса довольно сложно даже на дорогих трактах, и зачастую покупка карты топ класса - это желание иметь качественный компонент в цепочке звукового тракта. И когда выявляются такого плана баги, возникает мысль, а вдруг именно этот баг не даст раскрыться потенциалу устройства на все 100%, и стоит ли именно такой недоработанный компонент включать в высококачественный тракт? Сама идеология Hi-End не приемлет подобного рода компромиссов и ошибок в мелочах. И здесь интерес со стороны аудиофилов к Essence STX будет действительно большим, если проблемы, замеченные в линейке Xonar, будут решены. В противном случае карту не спасет ни ЦАП, ни ОУ.
    В любом случае, можно приветствовать выпуск такого продукта, т.к. использование таких фич, как топовый ЦАП и сменные ОУ, начнёт подхватываться и другими производителями. И если ASUS так и не решат свои проблемы, то велика вероятность, что проблем не будет у других производителей.
    Регистрация не подтверждена Аватар для =YVT=
    Цитата Сообщение от Buzzer Посмотреть сообщение
    Спёрто с хобота
    Как я понял карта с DSP, скорее всего пересчеты будут именно в нем.
    Кстати, а никто не задумывался над тем, что различного рода манипуляции с битовым потоком происходят и в очень дорогих DVD(DVD-Audio) плеерах.. Ведь там очень много чего предусмотренно, это и цифровая регулировка громкости, эквалайзер и множесто всего другого.
    На мой взгляд это еще один весомый аргумент в пользу построения хорошего внешнего ЦАПа для стационарного компьютера или ноутбука.
    В аналоговой аппаратуре обычно предусматривалась кнопка Direct или Tone Control, позволяющая обойти эквалайзер или РТ, но что самое смешное, судя по схемотехнике обычно отключается пассивная часть таких регуляторов, а активная остается для соглавования уровней и импедансов
    Украина Николаев
    карточка кстате уже в продаже по цене 200 юсд
    Старый знакомый Аватар для SAMUEL
    cka3o4nuk, где?
    Украина Николаев
    блин у нас всегда всё с нереальными задержками появляеца, карта от onkyo вообще не понятно когда будет и есть ли она вообще.
    Украина Николаев
    карта от онкио это калеченный аудиотрак хд2 зачем она вам?
    Старый знакомый Аватар для SCSRT
    Северодонецк
    А тестов еще нету? Сравнений с аналогами...
    да хз, я ж не спец в схемотехнике и т.п., почитал проосто отзывов лестных. а так жду асус
    Новичок Аватар для leninSama
    Обзор есть? Интерисует всё о ней, качество звука прежде всего
    завтра будет... лучше
    Частый гость Аватар для 74dva
    Не доверяю я инет-магазинам - возят товар с некоторыми дефектами, в надежде, что вдруг покупатель не заметит и возврат не будет делать.
    Одно радует: у бестолковой Creative, наконец-то, появился достойный конкурент....
    Последний раз редактировалось EDDiE; 26.03.2009 в 22:52. Причина: Добавлено сообщение
    Новичок Аватар для Balgem
    Обзор http://www.fcenter.ru/online.shtml?a...e/sounds/26344
    Опять до идела не дотягивает. Где же он идеал то?
    Если с работой самой Xonar Essence STX у меня не возникло совершенно никаких проблем, то попытка прописать в одной операционной системе одновременно две карты семейства Xonar не увенчалась успехом.
    Не знаю, как дело обстоит с Creative X-Fi Elite Pro, но с более ранними версиями Creative установка в системе одновременно двух карт этой фирмы тоже приводила к таким же печальным последствиям.
    Так, чтааа, автор немного, того, предвзят...
    ....а на следующий день... на следующий день Creative X-Fi Elite Pro отказалась работать.
    Потратив половину дня на тщетные попытки установить хоть какой-нибудь драйвер на неизвестное звуковое устройство Creative, в которое превратилась X-Fi Elite Pro,
    Creative X-Fi Elite Pro, только в такое устройство и умеет "превращаться"....
    Последний раз редактировалось EDDiE; 27.03.2009 в 21:24.
    Завсегдатай Аватар для Dmitr_RE
    Цитата Сообщение от Balgem Посмотреть сообщение
    ерунда все эти обзоры
    Все эти элит про,асусы, прелюды и продиджи звучат на одном уровне. Разница в нюансах, которые зависят от тракта, вкусов, ушей, настроения, уровнем алкоголя в крови, температуры в помещении и влажности))) и тд. Сегодня у слушателя рулит элит про в режиме ентертаинмент, завтра в audio creation, через неделю асус STX всех надерет а потом опять элит.
    Еще не стоит забывать, что человечкам деньги платят за статьи.
    да причем тут креатив, человек возможно сам что то намутил там
    У меня работает более года, самая стабильная карты из всех что были у меня.
    Частый гость Аватар для deniskin
    Kyiv-Fl320
    в коммутации похоже сигнальные реле
    very good
    Best regards Denis
    Последний раз редактировалось EDDiE; 28.03.2009 в 01:43. Причина: Добавлено сообщение
