Страница 2 из 11 Первая 1234 ... Последняя
Показано с 21 по 40 из 204
Тема: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Перфекционист затейник
    Аватар для cka3o4nuk
    Украина Николаев
    По умолчанию ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    ASUS just released an audio precision report of its latest product Xonar Essence STX. (
    According to ASUS, the yet-to-be-release audio product Xonar Essence STX is “world’s first onboard headphone amp 600ohms headphone with <100dB THD+N”. What’s more, Xonar Essence STX isolated power sources for headphone output and normal audio output. The whole card is using Nichicon capacitors which is called “fine gold”. We don’t know the release date of the card, but it will become another expensive enthusiast audio product.
    Craving for the clearest audio source to support your precious headphone and speakers? Then let Xonar Essence STX amaze you. Being the world’s first audio card to achieve 124dB in signal-to-noise ratio, and capable of driving headphone with highest impedance under lowest 100dB distortion, your only concern will be hard to stop the heavenly music playback from Xonar Essence STX.
    Designed in Essence
    Perfectly sealed by improved EMI shield, Xonar Essence STX’s analog output path generates the purest audio ever from a sound card -124dB signal-to-noise ratio and 0.0003% distortion.
    Fine-selected Components
    With premium-quality digital-to-audio converter and audio-specific capacitors selected, Xonar Essence STX provides <10~90kHZ frequency response and 124dB dynamic range for your unlimited pleasure.
    Shines your beloved headphones
    Drives up to 600ohms headphones with less than 100dB distortion, the built-in headphone amp supports every available headphone in the market with unbelievable audio quality.
    Украина Николаев
    По умолчанию Re: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Цитата Сообщение от Dmitr_RE Посмотреть сообщение
    Все эти элит про,асусы, прелюды и продиджи звучат на одном уровне. Разница в нюансах, которые зависят от тракта, вкусов, ушей, настроения, уровнем алкоголя в крови, температуры в помещении и влажности))) и тд. Сегодня у слушателя рулит элит про в режиме ентертаинмент, завтра в audio creation, через неделю асус STX всех надерет а потом опять элит.
    Еще не стоит забывать, что человечкам деньги платят за статьи.
    простите но креатив путсь хоть мега пупер елит про даже рядом с ксонаром стх и хд2 не валялся.
    there is no going back...
    (c) Tony Gee
    Самое смешное, что у Криэйтива криворукие программисты.
    Завсегдатай Аватар для Dmitr_RE
    cka3o4nuk,
    на ваш вкус? или ЦАПы сравниваем?
    Добавлено через 17 минут
    Juli@ показала чистый спектр, а X-Fi Elite Pro — грязный
    с внешним блоком мерили? если кое где галочки не поставить с ним шумит сильно
    Последний раз редактировалось Dmitr_RE; 28.03.2009 в 02:20. Причина: Добавлено сообщение
    Украина Николаев
    на слух более чем нескольких человек которые прослушивали данные апараты.
    (c) Tony Gee
    cka3o4nuk,
    не ужели на столько большая разница в чистоте и детальности?
    Украина Николаев
    вопрос разницы стоит от остального тракта
    если цена его в пределах 1-2к уе может быть разница и небольшая. бюджетные решения все же
    (c) Tony Gee
    UA Donetsk
    Вопрос Re: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    просьба к владельцам карточки:
    - прогоните пожалуйста тест RightMark Audio Analyzer External loopback (line-out - line-in) и выложите общий результат
    интересует параметры в стандартном, домашнем компе
    для сравнения мой результат рядового креатива:
    Общие результаты
    Неравномерность АЧХ (в диапазоне 40 Гц - 15 кГц), дБ +0.02, -0.15 Очень хорошо
    Уровень шума, дБ (А) -98.4 Отлично
    Динамические диапазон, дБ (А) 98.4 Отлично
    Гармонические искажения, % 0.0013 Отлично
    Гармонические искажения + шум, дБ(A) -90.5 Очень хорошо
    Интермодуляционные искажения + шум, % 0.0037 Отлично
    Взаимопроникновение каналов, дБ -95.2 Отлично
    Интермодуляции на 10 кГц, % 0.0038 Отлично
    Общая оценка Отлично
    Завсегдатай Аватар для shkal
    Москва, Russia
    Новичок Аватар для Eagle
    г.Курган
    А с ASUS XONAR D2 кто нибудь сравнивал?
    Украина Николаев
    а зачем ? д2 на уровне креатива мб чуть получше.
    (c) Tony Gee
    г.Курган
    Так они же подобны.
    Украина Николаев
    Так они же подобны.
    производителем?
    (c) Tony Gee
    г.Курган
    И производителем и ЦАП.
    Украина Николаев
    PCM1796 цап
    д2 обычная мультимедийка многоканальная. простое питание простая плата. и тп и тд можно до бесконечности
    (c) Tony Gee
    г.Курган
    И все же сравнение на практике было?
    UA Donetsk
    shkal
    это буклет, замечательный буклет, но что реально в Вашем конкретно компе например?
    у меня карточка за 30у.е, сабж стоит 200у.е
    я хочу увидеть результат 3х минутного простого теста на сабже в рядовом системнике, лучше сохраненого в формате рмаа и определиться надо ли мне к ней стремиться
    Москва, Russia
    У меня её нет
    UA Donetsk
    shkal
    я понял
    у всех просто пока есть только впечатления с фоток и сайта асуса о её грандиозности
    ждём реальных владельцев
    на хоботе тема по ней мутная, имхо из сабжа революции не получилось
    Частый гость Аватар для Vladimir1970
    Новых пользователей не прибавилось? Любопытный образец.
    ДВ
    ||deniskin
    в коммутации похоже сигнальные реле
    very good||
    Похоже реле коммутирует сигнал от цапа либо на линейный Ус либо на телефонный по входу. Как-бы не very good.
