Показано с 1 по 3 из 3
Тема: YAMAHA MusicCast MCX-1000
    По умолчанию YAMAHA MusicCast MCX-1000
    Несколько дней назад стал обладателем такого вот чуда.
    MCX-1000
    Server can control and broadcast music to 8 locations
    • 1 Server plus 7 Clients (up to 5 wireless Clients)
    Hard Drive:
    • 80 GB hard Drive
    ° 1000 CD*s in 160kbps compressed MP3 format
    ° 100 CD in LPCM original format
    • larger capacity hard drive can be installed by authorized MusicCAST dealer
    Playback:
    • Music by Artist, Album, Genre, Playlist or all songs
    • Compatible with CDs, CD-R/RW discs and MP3 CDs (created using PC in variable bit rate)
    Recording:
    • Copy CD to hard drive in original format (Linear PCM)
    • Record External sources at 1x to the Hard Drive with analog or digital inputs
    ° Analog Level control on front panel
    ° Digital Level control on GUI menu
    • Create CDs with ease using the built-in CD-Recorder from Linear PCM music saved on the hard drive
    ° Hard Drive to CD-R media (Max 8x or 1x)
    ° Hard Drive to CD-RW media (Max 4x or 1x)
    ° Advanced Audio Master Quality Recording to Audio CD-R/RW media
    GUI (Graphical User Interface) Easy to use with on-screen display
    • Server and Client play control
    • Timer for Recording and Playback / Server and Client control
    Built-in Gracenote CDDB® CD recognition database
    • With internet access the latest CD recognition data is available from the Gracenote CDDB® Server
    Yamaha AV receiver control with RS-232C
    • Control: DSP, tuner, volume and other key receiver functions
    PS/2 connection port for Keyboard to edit text
    Headphone jack with level control
    IR remote control
    Connections:
    • Network:
    ° Wireless IEEE 802.11b network protocol to communicate with clients
    ° Ethernet connection for CAT-5 link:
    - To connect wired Clients via Hub to Server
    - To home network for internet access
    • Audio
    ° Input: Analog, 2 Digital (1 optical, 1 coaxial)
    ° Output: Analog, 2 Digital (1 optical, 1 coaxial)
    • On-screen display output - S-video, Composite
    Dimensions (W x H x D):
    17-1/8" x 4-3/4" x 15-5/8"
    Weight:
    24.2 lbs.
    К сожалению производитель более не поддерживает эту модель в плане софта, и на офф. сайте есть только первая версия прошивки. После долгих поисков мануалов и прошивок на евро-американских форумах решил создать эту тему, где и хочу собрать всё в кучу для отечественного собрата владельца.
    Собственно, к делу:
    Yamaha MysicCast MCX-1000 Recovery CD. Это главный сервисный инструмент для аппарата - (http://rapidshare.com/files/44034358...0_Recovery.rar)
    Последняя известная прошивка на данный момент - (http://rapidshare.com/files/44033449...Update_4.1.nrg)
    Старенькая прошивка с сайта производителя - (http://www.yamaha.co.jp/english/prod...ad/YMCVUP1.zip) и Version Upgrade Manual к ней - (http://www.yamaha.co.jp/english/prod...rsionUp_EL.zip)
    Service Manual - (http://www.eserviceinfo.com/download.php?fileid=53759)(пять архивов), либо тут - (http://ru.nodevice.com/manual/newmans/yamaha/Mcx1000pdf/get59639.html) (нужна регистрация).
    Quick Manual - (http://www.manualowl.com/p/Yamaha/MCX-1000/Manual/19170)
    Что то не найду Owner*s Manual... но у меня он есть.
    Возможно в недалёком упакую всё это в архив и залью куда нибудь на "депозит" или "рапиду".
    Ну, в общем, спрашивайте, делитесь своими знаниями и удачи всем!
    По умолчанию Re: YAMAHA MusicCast MCX-1000
    https://disk.yandex.ru/d/gzJQ45ASz692uA
    RecoveryCD2003 + UpdateCD2004 + Service manual
    И чем он может представлять интерес кроме как музейного экспоната?
