5. Does the system have a “sweet spot” where you must sit for good sound?
No. In the vertical dimension, the sound will always appear to come from an area centered at the region of your listening height. For many systems, the sound changes when you are standing and then sit down. When you try this with the IDS-25, the sound, whether it is stereo or monophonic, does not change at any listening height.
In the horizontal dimension, stereo sound can seem to come from almost anywhere but the speakers. Sounds can be located in a wide horizontal area. Even if you are listening way over to one side, you can still hear excellent stereo, depth and spaciousness.
When listening to monophonic material, the sound image will appear to be exactly in the center between the speakers at all frequencies. However, a monophonic image will follow you as you move from left to right and if you are directly in front of one speaker, the sound will appear to come only from that speaker and not the other one.
No matter how the recordings are made, the sound images will be revealed with razor sharp accuracy when heard with a pair of the IDS-25 Stereo Loudspeaker Systems.
