Показано с 21 по 40 из 61
Тема: Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    Перфекционист затейник
    Украина Николаев
    По умолчанию Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    http://www.zaphaudio.com/SB12.3/
    INTRODUCTION
    This is a large floor standing three way system using SB Acoustics drivers. We use the SB29RDC-C000-4 ring radiator dome tweeter, affectionately known as the dimple dome. For the mids, we use a pair of SB15NRXC30-8 5" midwoofers, and finally a SB34NRX75-6 12" woofer to handle the low end. These are all drivers with very high performance at a good price, and the build quality is excellent. The midrange and tweeter are fully tested and reviewed in the comparisons elsewhere on this site, and the 12" woofer test results are posted below.
    Small designs are a dime a dozen, but very large multi-way designs are not so common. I teamed up with Madisound to "go big" in a big way and this project is the result. The world is full of tiny designs that might find their way to a small shelf, hidden between a plant and some books. This is a design for the other end of the home decor spectrum - when a visitor walks into the room, they can*t help but say "holy crap, look at those speakers!"
    There were a couple of directions we could have gone with this selection of drivers. It came down to the decision between front mount and a side mount woofer. Those two layouts require different crossovers so we had to pick one. We decided on the layout that could be described as "classic wide". These are much more than party speakers however. The design is high end throughout and I can*t even fathom how much a system like this might cost in the retail world. If I had to take a guess, I*d say somewhere in the 5 digit range. While this system is still not exactly cheap, DIY brings the cost down to be much more affordable.
    думаю стоит собирать
ID:	68829   Нажмите на изображение для увеличения.
    По умолчанию Re: Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    Сюда-бы легкий прошный мидбас
    звук соответcтвенный, легкий и тощий
    Эта трех полоска басит по очень взрослому и это хорошо. Конкретная АС для какой то конкретной музыки.
    Завсегдатай Аватар для Yurgen
    Из Замкадья
    Не скажи, сдвоенные восьмерки дают шикарный бас, только стоят они нехило те которые правильные.
    Добавлено через 45 секунд
    И гудит тоже не по детски
    Последний раз редактировалось Yurgen; 27.11.2009 в 23:56. Причина: Добавлено сообщение
    Украина Николаев
    зависит от криворукости делающего корпус.
    Москва, Бун.Луга
    Не только.
    Украина Николаев
    Не только.
    недумаю что запх тупее большинсва любителей обитающих сдесь
    old chap
    Зависит от убогости конструкции...
    Он хитрее, (пипл хавает) он и лепит!
    Последний раз редактировалось subsonic; 28.11.2009 в 00:38. Причина: Добавлено сообщение
    объясни почему?
    Можно представить, что нужен усилок для таких басовиков с могучим контролем, корпус лютый , помещение по просторней и хорошо акустически подготовленное.
    Украина Николаев
    тут не спорю
    прочитал легкий прочный мидбас и подумал что речь про мидбасы 6"
    Сдвоенные 8 это конечно хорошо, но один 12 в раене 30-40Гц должен с меньшими искажениями играть.
    Ростов
    зато две восьмерки будут быстрее играть,этот 12*** имеет большую массу подвижки,по моему,относительно неудачная контрукция,я бы не стал такие гробы конструировать если были бы деньги.
    old chap
    Про 8" даст динамичный мидбас, а 12" добавит "резины" на низах, две большие разницы!
    Добавлено через 28 минут
    В данном случае и могучий усилок мало чем поможет!
    Последний раз редактировалось subsonic; 28.11.2009 в 13:18. Причина: Добавлено сообщение
    Частый гость Аватар для INFRA
    Гусь-Хрустальный, Владимир.
    С 12" басовиком надо задумываться о четырёх полосках уже.
    12" до 80гц активная секция, можно уменьшить объем корректором линквица
    8" до 300-800гц пассивная секция, динамик с лёгким диффузором
    5" до 2500- 5000гц , можно купольник например вифа 75
    1" пищалка
    отдельный саб это плохо, когда он один ещё хуже, 2 это нормально , позволяет скорректировать влияние помещения, а если они в колонках вообще отлично.
    Крепить басовик сбоку как показала практика имеет только в недорогих конструкциях, скорострельность падает, и бассовые ноты становятся менее различимы (эксперементы проходили на линксах (усил и цап))
    old chap
    Кто Вам такое сказал?
    Собственный опыт. и опыт моих товарищей, при обычных условиях обычной комнаты, очень трудно создать равномерное звуковое поле одним сабом (другое дело два), для кино может его и достаточно, главное чтоб бухало, а музыка искажается, весь диапазон должны играть колонки!
    old chap
    Блажен ,кто верует...
    видимо я соскучился по "резиновым" басам быстрые мидбасы 6,5" в домашке уже надоели...
    Из Замкадья
    Цитата:
    Сообщение от INFRA
    Так это и так давно известно, одиночный саб либо будет гудеть если в угол поставить, либо не будет гудеть но и баса тоже не будет. Но это все в случае типичной комнаты 2.5 высота потолков, 15-18м2 площадь, если комната метров 40 то может и нормально будет.
    Добавлено через 3 минуты
    Может просто давления создаваемого на 40-50Hz не хватает, поэтому и не колбасит от них.
    Последний раз редактировалось Yurgen; 29.11.2009 в 15:05. Причина: Добавлено сообщение
    Yurgen,
    Скорее не давления, душа требует МАСШТАБА
    Москва, Бун.Луга
    Yurgen,
    И много $$$$ на 100 квадратов для масштаба.
    Именна так
