Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libclass-isa-perl libicu52 libmp4v2-2 libnfs4 libswitch-perl
Use *apt-get autoremove* to remove them.
The following packages will be REMOVED:
mpd
0 upgraded, 0 newly installed, 1 to remove and 315 not upgraded.
16 not fully installed or removed.
After this operation, 896 kB disk space will be freed.
Do you want to continue [Y/n]? Y
(Reading database ... 28433 files and directories currently installed.)
Removing mpd (0.19.9-1) ...
Setting up initscripts (2.88dsf-58) ...
Installing new version of config file /etc/init.d/bootmisc.sh ...
Installing new version of config file /etc/init.d/checkfs.sh ...
Installing new version of config file /etc/init.d/checkroot.sh ...
Installing new version of config file /etc/init.d/checkroot-bootclean.sh ...
Installing new version of config file /etc/init.d/halt ...
Installing new version of config file /etc/init.d/killprocs ...
Installing new version of config file /etc/init.d/mountall.sh ...
Installing new version of config file /etc/init.d/mountall-bootclean.sh ...
Installing new version of config file /etc/init.d/mountnfs.sh ...
Installing new version of config file /etc/init.d/mountnfs-bootclean.sh ...
Installing new version of config file /etc/init.d/mountdevsubfs.sh ...
Installing new version of config file /etc/init.d/mountkernfs.sh ...
Installing new version of config file /etc/init.d/rc.local ...
Installing new version of config file /etc/init.d/reboot ...
Installing new version of config file /etc/init.d/rmnologin ...
Installing new version of config file /etc/init.d/sendsigs ...
Installing new version of config file /etc/init.d/single ...
Installing new version of config file /etc/init.d/umountfs ...
Installing new version of config file /etc/init.d/umountnfs.sh ...
Installing new version of config file /etc/init.d/umountroot ...
Installing new version of config file /etc/network/if-up.d/mountnfs ...
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match mountkernfs.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match mountkernfs.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match hostname.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match hostname.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match mountdevsubfs.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match mountdevsubfs.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match checkroot.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match checkroot.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match checkroot-bootclean.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match checkroot-bootclean.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match checkfs.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match checkfs.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match mountall.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match mountall.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match mountall-bootclean.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match mountall-bootclean.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match mountnfs.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match mountnfs.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match mountnfs-bootclean.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match mountnfs-bootclean.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match bootmisc.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match bootmisc.sh Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match urandom Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match urandom Default-Stop values (0 6)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match halt Default-Start values (none)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match halt Default-Stop values (0)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match reboot Default-Start values (none)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match reboot Default-Stop values (6)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match umountroot Default-Start values (none)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match umountroot Default-Stop values (0 6)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match umountfs Default-Start values (none)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match umountfs Default-Stop values (0 6)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match umountnfs.sh Default-Start values (none)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match umountnfs.sh Default-Stop values (0 6)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match sendsigs Default-Start values (none)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match sendsigs Default-Stop values (0 6)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match killprocs Default-Start values (1)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match killprocs Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match single Default-Start values (1)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match single Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match motd Default-Start values (1 2 3 4 5)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match motd Default-Stop values (none)
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match bootlogs Default-Start values (1 2 3 4 5)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match bootlogs Default-Stop values (none)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match rc.local Default-Stop values (none)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match rmnologin Default-Stop values (none)
Setting up libkmod2:armhf (18-3) ...
Setting up libpipeline1:armhf (1.4.0-1) ...
Setting up libudev1:armhf (215-12) ...
Setting up groff-base (1.22.2-8) ...
Setting up bsdmainutils (9.0.6) ...
update-alternatives: using /usr/bin/bsd-write to provide /usr/bin/write (write) in auto mode
update-alternatives: using /usr/bin/bsd-from to provide /usr/bin/from (from) in auto mode
Setting up man-db (2.7.0.2-5) ...
Building database of manual pages ...
Setting up kmod (18-3) ...
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match kmod Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match kmod Default-Stop values (none)
Setting up alsa-base (1.0.27+1) ...
Removing obsolete conffile /etc/modprobe.d/alsa-base.conf ...
Removing obsolete conffile /etc/modprobe.d/alsa-base-blacklist.conf ...
Removing obsolete conffile /etc/default/alsa-base ...
Setting up libaudit-common (1:2.4-1) ...
Setting up libaudit1:armhf (1:2.4-1+b1) ...
Setting up ifupdown (0.7.53.1) ...
Installing new version of config file /etc/init.d/networking ...
Installing new version of config file /etc/init/network-interface-container.conf ...
Installing new version of config file /etc/init/network-interface-security.conf ...
Installing new version of config file /etc/init/network-interface.conf ...
Installing new version of config file /etc/init/networking.conf ...
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match networking Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match networking Default-Stop values (0 6)
Setting up dmsetup (2:1.02.90-2.1) ...
update-initramfs: deferring update (trigger activated)
Setting up libdevmapper1.02.1:armhf (2:1.02.90-2.1) ...
Setting up libcryptsetup4:armhf (2:1.6.6-5) ...
Processing triggers for initramfs-tools (0.109.1) ...
localepurge: Disk space freed in /usr/share/locale: 0 KiB
localepurge: Disk space freed in /usr/share/man: 0 KiB
Total disk space freed by localepurge: 0 KiB
