Показано с 1 по 20 из 31
Тема: Дискретный R2R дак
    Перфекционист затейник
    Украина Николаев
    По умолчанию Дискретный R2R дак
    http://www.diyaudio.com/forums/vendo...t-384-khz.html
    I have been working on a little side project, now it*s time to present it for everybody here....
    It*s a DAC module based on a discrete R-2R sign magnitude DAC design, with FPGA based reclocking and custom digital filters, < 1 ps jitter clock generator, with 28 bit resolution so there is headroom, oversampling up to maybe 3.072 Mhz. Up to 24 bit / 384 Khz input from SPDIF, I2S and USB (via USB to I2S interface board), with isolation on the I2S interface. The board will be very flexible, with digital volume control and filter parameters that can be downloaded, a possibility is also to add digital crossover filters, but that will probably not be ready for first production lots, although the board is firmware upgradable over a simple serial connection.
    The basis R-2R network has an output voltage of 1.4V RMS and output impedance of 1.2 Kohm and can therefore drive a lot of things directly.... There is also onboard balanced output drivers that can drive high impedance (>= 300 ohm) headphones directly. The power supply is also onboard, just add a 5W toroid transformer.
    It is a small mostly surface mount PCB, and yes, I have working prototypes, see below.... But it*s not really something for home assembly, with the FPGA in BGA package and 600 pcs SMT parts.... So yes, if there is enough interest it will go into real production, with sales though two existing online shops in US and EU.
    Performance of first prototypes using 0.05% resistors is better than expected, see 1 Khz -1 db and -60 db FFT plots. I believe that the sound quality will be the absolute best, better than any Delta Sigma DAC, in class with discrete DAC*s from totaldac and msb technology. And for way way less cost
    Update on Aug 6:
    Thanks for all the nice words and interest. The board will definite go into production, leadtime on the precision resistors is the limiting factor, I*m trying for a ship date of early to mid November for the first batch of 240 boards, then more boards in December. Planing for about 25% 0.01% version, 50% 0.02% version and 25% 0.05% version. Preliminary pricing is:
    0.05% resistor version USD 170 / EUR 127
    0.02% resistor version USD 240 / EUR 179
    0.01% resistor version USD 350 / EUR 261
    Shipping cost and any local taxes to be added.
    They will become available to order though two existing webshop (no info there yet):
    помоему довольно интересная штука
    с демократичной ценой.
    сделано вполне аккуратно.
    Калуга
    По умолчанию Re: Дискретный R2R дак
    В чем?
    Вопрос без всякой подколки.
    Штука интересна тем, что толпа народу выстроилась в очередь за дискретным 28бит r-2r цапом, с выходом по напряжению и ключами 595.
    Они там совсем с ума посходили.
    WBR, Michael.
    Завсегдатай Аватар для l3VGV
    Псков
    Пока не 28, пока ещё только 24, что не менее смешно. Но думаю дальше будут сразу 32 и 48, мегагерц сразу на 6. А чо, всё что надо так это ещё пару регистров! Ведь всё просто. Главное золотые резисторы 0.01%, остальное фигня и маркетинговое разводилово!!!
    Самый простой и действенный маркетинг: куча очевидных для случайного человека вещей. Проверить не очевидное он не догадается.
    Pskov
    Помнится ныли про сложность изготовления R-2R ЦАПа на 12 бит на рассыпухе, а тут сразу 24
    в мире нанотехнологий такие игрушки это 2 шага назад
    Ветку там читал кто ? Измерения проверяли ? Подобные ("true" r2r) конструкции хорошо если -90 дб достигают (msb к примеру), а тут сразу -100 почти Другое дело, что эти 80 90 100 дб на стационарном сигнале слабо коррелируют с качеством звучания имхо
    Королев
    Вот ещё один француз подобные ЦАПы делает:
    http://www.totaldac.com/REFERENCE-D1-eng.htm
    Это суть хайэнда в чистом неприкрытом виде.
    Йыхви/Эстония
    помолился за человечество в этой теме.
    Pskov
    Наши тож не лыком шиты, никто не пробовал?
    http://niiemp.ru/produktsiya-i-uslug...i-atsp-vt.html
    BLR
    Вполне реальные замеры, ничего криминального.
    Во первых это не чистый R2R, а сегментированный (как и MSB), потому и -100. Иначе было бы на 2..3 десятка децибел хуже.
    Во вторых чисто из принципа, при использовании деглитчера и калибровки, на такой схемотехнике можно опуститься и до -110, и ниже (по крайней мере в небольшом интервале температур). Только для этого давным давно существую интегральные конвертеры. Причем для этих несчастных -95..100дБ хватит и 16 бит приборов.
    Тип сигнала для обмера параллельных ЦАП не имеет значения, на звуке будет то же самое. Если в случае УМ еще можно говорить о недостоверности измерений на стационарном сигнале (из-за конверсии амплитудных искажений в фазовые, или из-за реактивностей АС), то с параллельными ЦАП в плане измерений все гораздо "прозрачнее". Палки на спектре - обыкновенные диф. нелинейности и кореллированные с сигналом глитчи, если их нет на стационарном сигнале, то не будет и на любом другом.
    28. с одного регистра используют 7 бит.
    4 бита нижних для цифровой регулировки громкости.
    ---------- Сообщение добавлено 00:44 ---------- Предыдущее сообщение было 00:40 ----------
    А где там есть деглитчер?
    Там же нет S/H
    WBR, Michael.
    BLR
    Там, судя по фото колинеар, 23+23 = 24 бита. 7 старших - не биты, а сегменты, т.е. это 3 старших бита.
    Скорее 8 нижних бит. Т.к. с ростом амплитуды сигнала пропорционально растет и шумовая полка из-за нелинейностей младших разрядов, ограничивая ДД теми же 100дБ.
    Наши лыком не шиты, нормальные камни с токовым выходом с ключами с входом опорника и тд.
    25 лет назад пробовал. Изучил внутренности 572па1, и подумал ну что за дураки, токовый выход неудобный Включил ее совсем не по даташиту, получив выход по напряжению прямо с матрицы.
    Оно даже подавало признаки жизни
    WBR, Michael.
    BLR
    Там же нет S/H
    А кто говорит что он там есть? Нет конечно.
    Если бы все так просто было давно уже была бы совершенная техника. А звуковые карточки с -110 дб почему-то не играют. Сейчас вот ЦАПа нет. Слушаю с ДВД - думаю теже 100дб, а со звуком есть вопросы
    Из соседней темы сравнения мультибитных старичков с Хелиусом https://forum.vegalab.ru/showthread....=1#post1963661
    "Собственно по звуку - даже не знаю чего тут рассказывать. Просто нормальный аппарат, всё на месте, всё как положено. Лично мне не хватало динамики и разрешения, но это в сравнении с приборами сильно другого уровня."
    Хотя честно говоря отзыв под сомнение поставил бы все-таки этот, тем более что апогей слушал и ты.
    Евродупло
    Тут прячутся половые монстры: http://mola-mola.nl/index.php/blog
    Хай-эндЪ не терпит суеты.
    Старый знакомый Аватар для krulfa
    Скорее всего, никакими ухищрениями не удастся избавиться от металлического окраса в звуке.
    А в остальном да, звук будет выразительный.
    ---------- Сообщение добавлено 08:00 ---------- Предыдущее сообщение было 07:23 ----------
    В структуре R-2R токи через ключи и резисторы зависят от кода. Резисторы подвержены тепловым искажениям, а ключи и тепловым, и нелинейным. Если делать калибровку, то она будет действительна только на сигнале той формы и спектра, на котором делалась калибровка. На сигнале с другим спектром распределение мощности и температуры на элементах будет другим и калибровка уедет.
    "Земля" - это всего-навсего еще один провод.
    BLR
    Так она давным давно уже есть. Просто никому не надо, "не звучитъ!". Аудиоаппаратура давно выродилась в сферу маркетинга и эксайтинга. Т.е. одни покупают аппаратуру за дизайн или детальки что в ней стоят, другие - за спецефический окрас ("звук"). А когда есть и то и другое, это уже настоящий хайэндъ. )
    Не обязательно, стотря как организовать смещение на выходе матрицы: если половина питания, то токи через ключи и резисторы будут постоянны. Но это все не имеет значения, т.к. там нелинейности чисто из-за разбросов результирующих сопротивлений матрицы, плюс глитч из-за разных времен переключения логики.
