Последний раз редактировалось Hunterkz; 13.05.2021 в 13:31.
Неужели нет на форуме спецов по прошивке раций?
C обратной стороны надписи какие есть?
ну ок, не похожа
приму в дар видеокарту ET6000 TsengLabs
нашел на
http://www.airsoftcanada.com/showthread.php?t=38153
похоже, только эти частоты
1 GMRS/FRS 462.5625
2 GMRS/FRS 462.5875
3 GMRS/FRS 462.6125
4 GMRS/FRS 462.6375
5 GMRS/FRS 462.6625
6 GMRS/FRS 462.6875
7 GMRS/FRS 462.7125
8 FRS 467.5625
9 FRS 467.5875
10 FRS 467.6125
11 FRS 467.6375
12 FRS 467.6625
13 FRS 467.6875
14 FRS 467.7125
15 GMRS 462.5500
16 A GMRS 462.5750
17 GMRS 462.6000
18 B GMRS 462.6250
19 GMRS 462.6500
20 C GMRS 462.6750
21 GMRS 462.7000
22 GMRS 462.7250
As you know you must put the SQL at 12.5 Hz. To do this, press on the FUNCTION button and *. Twist the ENC/SQL knob and choose either 10, 12.5 or 25 Hz then press DIAL.
To memorize the frequencies:
Type in the frequency, then press on FUNCTION. Twist the ENC/SQL knob and choose the number you want to lock the frequency to then press SCAN(i.e.: number one for the first frequency and so on…) To access the memory, press SCAN one time and twist the knob to navigate between frequencies. If you hold SCAN too long you will just cycle through the frequencies.
и еще:
About "Sub Channels"
CTCSS (Continuous Tone Controlled Squelch System) is an advanced sub-coding system that allows segmentation of a main channel. When you transmit using CTCSS you are transmitting on one of the main FRS or GMRS channels but you are transmitting an inaudible tone that controls the squelch. To understand how this works think of squelch as a gate that opens only under certain conditions. When it is opened your radio allows the signal to be received and you hear the transmission. Normally, squelch is a gate that is activated by signal strength - the signal must be strong enough or the gate (squelch) won*t open. In CTCSS squelch is controlled by an inaudible sub-tone - without the proper sub tone the gate (squelch) won*t open regardless of signal strength.
An FRS or GMRS radio equipped with CTCSS allows it*s squelch to be broken (allows an incoming signal to be heard) only when it receives a special low frequency tone transmitted by another FRS on the same subchannel. To use CTCSS sub-channels you would set two FRS radio*s, equipped with CTCSS, to the same channel and same sub-channel. This way both radios would be transmitting the same low frequency tone when transmitting and looking for the same low frequency tone when receiving.
CTCSS is a useful feature when you only want to hear from a certain radio or group of radios and not everyone else since your radio*s squelch will only open when it receives the sub-frequency assigned to the sub-channel you are on. This will stop you from hearing other transmissions on the same channel and/or same channel with different sub-channel.
It is important to note that CTCSS does not provide you with privacy - all it does is eliminate the number of signals your radio will allow you to hear! Your transmission can be received/overheard by any other FRS radios on the same channel - Once your signal is on the air, the signal is fair game to be received by other FRS radios, GMRS radios or scanners. Additionaly, any UHF radio tuned to the "parent" frequency, and not subscribing to the CTCSS, will overhear any transmission sent on that channel. The UHF set*s transmissions will be ignored by the recieving FRS or GMRS radio however, unless the corresponding CTCSS code is activated on the UHF set.
Amateur radios operating in the GMRS or FRS frequency range can be configured to use CTCSS "Sub Channels" by configuring the CTCSS tone frequency.
The following is a list of sub-channel CTCSS frequencies:
Code Freq (Hz)
1 67.0
2 71.9
3 74.4
4 77.0
5 79.7
6 82.5
7 85.4
8 88.5
9 91.5
10 94.8
11 97.4
12 100.0
13 103.5
14 107.2
15 110.9
16 114.8
17 118.8
18 123.0
19 127.3
20 131.8
21 136.5
22 141.3
23 146.2
24 151.4
25 156.7
26 162.2
27 167.9
28 173.8
29 179.9
30 186.2
31 192.8
32 203.5
33 210.7
34 218.1
35 225.7
36 233.6
37 241.8
38 250.3
Putting it all together
So, if you are using a UHF radio configured to access the 462-468Mhz band for FRS / GMRS access, and you*ve been directed to use FRS channel 14-21, you would set your transeiver to 467.7125 with CTCSS tone 136.5.
С уважением.
Юрий.
Свасибо Юрий!
Перевел, может кому надо:
Как вы знаете, вы должны установить SQL на 12,5 Гц. Для этого нажмите кнопку FUNCTION и *. Поверните ручку ENC / SQL и выберите 10, 12,5 или 25 Гц, затем нажмите DIAL.
Чтобы запомнить частоты:
Введите частоту, затем нажмите FUNCTION. Поверните ручку ENC / SQL и выберите номер, на котором вы хотите зафиксировать частоту, затем нажмите SCAN (то есть: номер один для первой частоты и т.д. до 226). Чтобы получить доступ к памяти, нажмите SCAN один раз и поверните ручку для перехода между частотами. Если вы будете удерживать SCAN слишком долго, вы просто будете переключать частоты.
и еще:
О "дополнительных каналах"
CTCSS (система шумоподавления с непрерывным тональным управлением) - это усовершенствованная система субкодирования, которая позволяет сегментировать основной канал. При передаче с использованием CTCSS вы передаете по одному из основных каналов FRS или GMRS, но передаете неслышный тональный сигнал, который управляет шумоподавлением. Чтобы понять, как это работает, представьте шумоподавитель как ворота, которые открываются только при определенных условиях. Когда он открыт, ваше радио позволяет принимать сигнал, и вы слышите передачу. Обычно шумоподавитель - это гейт, который активируется силой сигнала - сигнал должен быть достаточно сильным, иначе гейт (шумоподавитель) не откроется. В CTCSS шумоподавитель управляется неслышимым субтоном - без правильного субтона шлюз (шумоподавитель) не откроется независимо от силы сигнала.
Радиостанция FRS или GMRS, оснащенная CTCSS, позволяет расшифровать шумоподавление (позволяет слышать входящий сигнал) только тогда, когда она принимает специальный низкочастотный тон, передаваемый другим FRS на том же подканале. Чтобы использовать подканалы CTCSS, вы должны установить два радио * FRS, оборудованных CTCSS, на один и тот же канал и один и тот же подканал. Таким образом, обе радиостанции будут передавать один и тот же низкочастотный тон при передаче и искать один и тот же низкочастотный тон при приеме.
CTCSS - полезная функция, когда вы хотите слышать только определенное радио или группу радио, а не все остальные, поскольку шумоподавитель вашего радио * откроется только тогда, когда он получит подчастоту, назначенную для подканала, на котором вы находитесь. Это помешает вам слышать другие передачи на том же канале и / или на том же канале с другим подканалом.
Важно отметить, что CTCSS не обеспечивает конфиденциальность - все, что он делает, это устраняет количество сигналов, которые ваше радио позволяет вам слышать! Ваша передача может быть принята / подслушана любыми другими радиостанциями FRS на том же канале - как только ваш сигнал будет в эфире, сигнал будет принят другими радиостанциями FRS, радиостанциями GMRS или сканерами. Кроме того, любое радио UHF, настроенное на «родительскую» частоту и не подписанное на CTCSS, будет подслушивать любую передачу, отправляемую по этому каналу. Передачи УВЧ-набора будут игнорироваться принимающей радиостанцией FRS или GMRS, если только на УВЧ-приемнике не будет активирован соответствующий код CTCSS.
Радиолюбители, работающие в частотном диапазоне GMRS или FRS, можно настроить для использования «Подканалов» CTCSS путем настройки частоты тона CTCSS.
Ниже приведен список частот CTCSS подканалов:
Код Частота (Гц)
1 67,0
2 71.9
3 74.4
4 77.0
23 146.2
24 151.4
25 156.7
26 162.2
27 167.9
28 173.8
29 179.9
30 186.2
31 192.8
32 203.5
33 210.7
34 218.1
35 225.7
36 233.6
37 241.8
38 250.3
Собираем все вместе:
Итак, если вы используете радиомодуль UHF, настроенный для доступа к диапазону 462–468 МГц для доступа FRS / GMRS, и вам было предложено использовать канал FRS 14–21, вы должны установить свой трансивер на 467,7125 с тоном CTCSS 136,5.
---------- Сообщение добавлено 19:07 ---------- Предыдущее сообщение было 19:04 ----------
Выходит моя рация меньше 450МГц не настраивается...
Может кто еще подскажет как эту станцию перепрошить с частот 450-470 на частоты 420-450 МГц?
На моей работе Моторола нам как-то перепрошивала свои похожие, так чувствительность упала втрое-использовать было невозможно.
У нас их просто несколько сотен, и выделили другие частоты, вот и решили сэкономить.
Последний раз редактировалось Yur_ka; 19.05.2021 в 07:45.
С уважением.
Юрий.
