Показано с 1 по 2 из 2
Тема: NXP BF862 warning
    iN GOD We TRUSt
    Аватар для EDDiE
    По умолчанию NXP BF862 warning
    two different providers (DigiKey Corp. | Electronic Components Distributor | United Kingdom Home Page and Mouser Electronics - Electronic Components Distributor). Both are 100% genuine NXP parts, the only difference being the origin. One batch is marked 2Aw (w stands for China) and the other 2Ap (p stands for Hong Kong).
    While they both have the noise floor @100KHz as per the datasheet (~0.8nV/rtHz), the Chinese parts have significantly larger noise corner frenquency (~2KHz) compared to the HK parts (<500Hz). Therefore, the Cninese parts have about twice the noise of the HK parts, @1KHz. Devices in both batches have essentially the same average Idss of about 16mA.
    Not a huge deal for audio, but could be an issue for low and very low frequency applications. BTW, the datasheet does not specify anything about the low frequency noise.
    https://www.diyaudio.com/forums/part...2-warning.html
    По умолчанию Re: NXP BF862 warning
    Две партии - слишком маленькая выборка для объективной оценки.
    И это если не смотреть ещё на дату оригинального поста - 2013 г. За 7 лет всё могло кардинально измениться.
