Показано с 1 по 7 из 7
Тема: MinorityClean - HQ Sound - Bug head Nontallion (PINK HQ Qctahedron)
    iN GOD We TRUSt
    Аватар для EDDiE
    По умолчанию MinorityClean - HQ Sound - Bug head Nontallion (PINK HQ Qctahedron)
    MinorityClean - Official home page
    https://translate.google.co.jp/trans...F~coolverse%2F
    Hello.
    Currently, I am developing an ultra-high quality PC transport in the world of hi-fi audio.
    With it used in the high-end audio show. example "HIGH-END"
    I wrote the source code with PureBasic BASS and FASM, and it has more than 20 million lines.
    That*s because it*s lengthened by the code generator.
    Bug head Nontallion - Official home page
    http://www.mics.ne.jp/~coolverse/
    Last year, I developed "MinorityClean" which sets the electronic register standard of
    the new CPU to the average state of the internal circuit of the memory chip.
    The CPU-based electronic standard utility that I made earlier was a failure sooner or
    later because it destroyed the keyboard, mouse, and printer after a long period of use.
    Stop use "All core any cures"
    How to run
    "MinorityClean.exe" run, Changes occur after 30 seconds.
    Stop effect
    Shutdown and power off.
    keep effect
    Kill process by task-manager, Windows re-start.
    result
    High-Quality Display, High-Quality Print, High-Quality Sound.
    The LCD monitor looks beautiful in gradation like organic EL.
    Printing is as high quality and beautiful as commercial printing.
    The sound is on par with the high quality sound player.
    Trouble reports have not been reported even if they depend on many users.
    JPLAY + MinorityClean
    HQ Player + MinorityClean
    WINAMP + MinorityClean
    foobar2000 + MinorityClean
    TuneBrowser + MinorityClean
    Attached document
    Assembler instruction used Intel x64 FPU MMX SSE2 SSE4.1
    Up to 32 cores (supports up to 32 threads)
    Effective environment
    Windows PC of Intel Core series such as Intel Core i5-8400
    Twenty seconds after the EXE resides, the CPU status is adjusted to the memory chip standard.
    If executed on a guest OS in a virtual environment, the effect will be affected on the host OS.
    Main effects
    The LCD monitor has no noise, beautiful gradation like organic EL, and clear text.
    The sound output is to the sound quality of a high-quality sound player.
    It runs in an infinite loop, ending when shutting down, and ending when the process is killed.
    The event monitoring program is not included for quality priority.
    << Scientific basis as hypothesis image >>
    In the process of writing data to the memory, the internal state of the memory chip is averaged
    using a continuous inversion bit for 64-bit MMX memory writing of full bit "1" and full bit "0".
    With averaged memory buffers, digital noise is very unlikely to occur.
    Download
    http://www.mics.ne.jp/~coolverse/MinorityClean/
    free software, Windows 64bit only, required FPU MMX SSE2 SSE4.1
    thank you. have fun.
    _________________
    My homepage in Japan - Bug head Nontallion http://www.mics.ne.jp/~coolverse/
    My facebook page. https://www.facebook.com/hiroyuki.yokota
    Official home page
    Последний раз редактировалось EDDiE; 08.02.2020 в 22:02.
    Старый знакомый Аватар для bbest
    По умолчанию Re: MinorityClean - HQ Sound - Bug head Nontallion (PINK HQ Qctahedron)
    Вы сами слушали это? Как впечателения?
    iN GOD We TRUSt
    Аватар для EDDiE
    Пока нет времени возиться с установкой этих двух прог.
    Если кто-то уже успел мз установить и послушать, прошу отписаться в теме.
    Старый знакомый Аватар для Mickhail
    Здравствуйте
    Ну собственно все живет и не умирает.
    Звучит выше всяких похвал. Прослушивал не только я ,но и несколько знакомых на разных системах,акустика и наушники. Везде слышалась разница в звуке между фубаром аплеером и Bug head Emperor 11.77. Значительно улучшалась разборчивость звуке, как следствие разделение каналов и глубина звука. Бас становится более упругим и мой саб очень благосклонно попросил прибавку в громкости без бубнежа. Это вкусности, а вот невкусности подкашивают на убой все радости.
    Комп 3ггц на интеле 3 степа с 8 гигами просто не годится ,при том что загрузка проца не более 3-5% и память флаковом звуковом диске 700мб, прогой занимает 2.5гига. Так вот обработка контента заняла около 20 минут и это не в максимальной конфигурации проги. При просьбе поработать в максимальной время на обработку одной записи 250мб заняла около 90 минут , успел пообедать и посмотреть форум . Блин эта хрень чего делает!!!!???
    Отдал товарищу на пробу , его конф компа I8-3600 -32Gb-SSD240. В предельной конфигурации 50 минут на один флак ! При том что комп фактически простаивал.
    Крайне жаль , не реальный ждунчик .
    Как то так
    iN GOD We TRUSt
    Аватар для EDDiE
    Возможно, именно для этого автором Bug head Nontallion написана прога MinorityClean
    У меня ASIO от ASUS, а у Bug head Nontallion есть в установочном пакете ASIO4ALL, что при установке Bug head Nontallion либо перезапишет ASIO от ASUS, либо, получится конфликт между ними...
    Завсегдатай Аватар для dalidovich
    Stavropol
    Программа MinorityClean не долго по времени обрабатывает звук. Точнее она звук совсем не обрабатывает. Загрузка ЦП 0% на стареньком процессоре. Хотя возможно и будет лучше на мощном, но не проверял.
    Для 64 бит сама программа MinorityClean.
    http://www.mics.ne.jp/~coolverse/Min..._Rev27_x64.zip
    Сама программа MinorityClean просто запускается (сперва её нужно распаковать, сама программа не устанавливается) и начинает работать через 30 секунд (т.е. в описании указывается, что через 30 сек меняется звук). Закрыть программу можно только как обычный процесс в диспетчере путём - снять задачу.
    Лучше всего эту программу MinorityClean запустить через вторую SEXE, там же на этом сайте есть.
    Описание SEXE с картинкой.
    https://www.nanshiki.co.jp/software/sexe.html
    Сама программа SEXE 64 бит. Её так же не нужно устанавливать. Запускать её для установки как службы MinorityClean от Администратора .
    https://www.nanshiki.co.jp/free/sexe64exe010.zip
    Кнопочки в SEXE на иероглифах, но всё понятно должно быть и так как настроить.
    Вторая просто делает из первой программы как службу в Виндовс. И после запускать не нужно вручную, автоматом стартует как служба Виндовс после включения компьютера.
    По звуку у меня - аппаратура совсем не очень, субъективная оценка - чуть чище звук и чуть мягче. Слушал в аплеере.
    Работает эта первая программа с любым плеером, с любым видеоплеером (с играми на пробовал) и вообще должно с любым звуком, без разницы.
    Так же в описании к программе пишется, что шрифты в Виндовс становятся лучше. Субъективно видение как немного уменьшение расплывчатости вокруг ореола букв, но видно только у меня на телевизоре по диагонали 90см (старенький), подключённый в качестве монитора.
    Проверка работы программы очень проста если установил как службу, убил как процесс в диспетчере. Слушаешь. Стартуешь службу, слушаешь и при необходимости повторяешь операции. Сама программа как служба после остановки, всё равно висит в процессах.
    Так же звук возможно меняется если менять приоритет программы на реального времени.
    гугл-перевод.
    Научная основа
    В процессе записи данных в память внутреннее состояние микросхемы памяти усредняется с использованием бита непрерывной инверсии при записи в 64-битную память MMX полного бита «1» и полного бита «0». При усредненных буферах памяти маловероятно возникновение цифрового шума. Цифровой выход без дрожания реализуется путем отражения этого состояния в регистрах ЦП и звуковых данных. Jitterless не был подтвержден, но я думаю, что это было достигнуто, потому что нет никакого изменения в звуке с полностью цифровым усилителем.
    Последний раз редактировалось dalidovich; 15.02.2020 в 13:55.
    Здравствуйте соконфетники
    Собственно программа то Bug Head Imperior в разных ипостасях. Варианта 4 .Собственно Bug Head в разной степени тяжести,вторая вариант Nontallion то же в разной степени тяжести,PINK HQ с различными вариантами и Qctahedron 2.64 с вариантами. MinorityClean костыль на фиг не интересный. а вот другие варианты тяжесть офигительная. Вот они и требуют ресурсы. Startup в их директориях Вам в помощь. Если дождаться конца обработки то тогда услышите звук , а так нет смысла в другом.
