Name: P-Audio HP-12W - 36 евро / 1 240р.
Type: Standard one-way driver
No. of Drivers = 1
Fs = 48, Hz
Qms = 4,99
Vas = 99,77 liters
Cms = 0,27 mm/N
Mms = 40,71 g
Rms = 2,46 kg/s
Xmax = 2, mm
Xmech = 3, mm
P-Dia = 254,8 mm
Sd = 510, sq.cm
P-Vd = 0,102 liters
Qes = 0,65
Re = 5,22 ohms
Le = 0,75 mH
Z = 8, ohms
BL = 9,93 Tm
Pe = 100, watts
Qts = 0,57
no = 1,67 %
1-W SPL = 94,29 dB
2.83-V SPL = 96,23 dB
Box Properties
Name:
Type: Vented Box
Shape: Prism, square
Vb = 103,5 liters
Fb = 28,14 Hz
F3 = 53,29 Hz
Fill = heavy
No. of Vents = 2
Vent shape = round
Vent ends = one flush
Dv = 100, mm
Lv = 400, mm
Кто что думает про такого зверька??? Ежели его домой в комнатку 25 м.кв. и ватт на 70-80 качнуть???
