Страница 2 из 2 Первая 1 2
Показано с 21 по 31 из 31
Тема:
    iN The FED We tRUSt
    Аватар для EDDiE
    По умолчанию Fakin* The Funk?
    Fakin* The Funk? https://fakinthefunk.net/en/#about
    версия с таблеткой валяется в сети
    Fakin* The Funk? is a tool that helps you to detect the true quality of your audio files in one batch.
    Nowadays you can download tunes from anywhere.
    But what is the real quality of these files?
    What if you could check those tunes to see if they’re really that good, and not upscaled 128kbps to 320kbps MP3s?
    You could batch-process them all without having to manually check them 1-by-1 using a spectrum analyzer?
    Automated batch-processing
    Easy-to-use interface
    Free (for the 1st 100 detected fake files)
    Lifetime updates (when donated to full version)
    Cannot be fooled by audio-optimizers like Platinum Notes
    Besides fake files, it detects corrupted & unreadable files as well
    Supports all popular lossy & lossless audio file formats
    Ultra-fast processing using multiple threads to speed up the analysis
    Drag-&-drop support e.g. to Mp3Tag or Explorer
    Shows frequency cut-off, using its built-in Spectrum analyzer
    Listen to audio files directly, using its built-in player
    Translated manually into English, Spanish, German, Italian, Dutch, French, Swedish & Polish
    Supports 24 bit formats & samplerates above 48 kHz
    Tag-editor for the most common ID-tags incl. search & replace feature
    Optional clipping detection
    Configurable toolbuttons to search songs online (Amazon, iTunes, etc.)
  2. Завсегдатай Аватар для Furious_Dima
    По умолчанию Re: Fakin* The Funk?
    Цитата Сообщение от Эзотехник Посмотреть сообщение
    http://forum.vegalab.ru/showthread.p...ll=1#post82343
    http://forum.vegalab.ru/showthread.p...ll=1#post81782
    http://www.diyaudio.ru/forum/index.php?topic=828.0
    "Дмитрий, а чем оцифровывался сигнал?
    В приведенном выше случае - AK5394. При работе с более широкополсными сигналами использую плату на основе AD7982. Платы стыкуются с ПК посредством PCI-контроллера собственной разработки на FPGA."
    А это цены SAR лазерно-подогнанных одноканальных в 2007 г. (сейчас их аналоги "всего" $22 стоят):
    "AD1376 Model Options
    Model Status Package Pins Temp Range Price* (100-499) Available RoHS Compliant Samples Cart Purchase Cart
    AD1376JD Prodn 32 ld Bottom-Brazed Hybrid DIP 32 Comm $234.00 4/13/2007 - Add to Cart
    AD1376KD Prodn 32 ld Bottom-Brazed Hybrid DIP 32 Comm $292.50 2/23/2007"
    Так это АВД тогда говорил, уже 14 лет прошло! С накопившимися за это время знаниями он за дельта сигму везде и двумя руками, а резистивные сборки это примитивные приборы.
    all amps dc coupled: 6sn7/6sl7 srpp 2a3; e280f 45; d3a 300B; 5998/we421a; 6gf7; 6em7; 6s45p grounded cathode; 4p1l filament bias, ren904 re604, hybrid circlotron 2sk1058
  3. Старый знакомый Аватар для Alex07
    Нальчик
  4. Старый знакомый Аватар для Эзотехник
    Ru
    Ему что выгоднее продавать - за то и агитирует. А раньше не был заинтересован в продажах, говорил правду.
    "Примитивный прибор" на резисторах от MSB ни одна дельтасигма не достигла по THD+N, SINAD и стоит он как 3-5 Аполло Чернова-Андронникова на AK4490.
    http://www.msbtechnology.com/dacs/se...ct-90db-graph/
  5. Завсегдатай Аватар для Михаил45
    Ты уже купил оба и сравнил? Круто, оказывается и сюда олигархи заглядывают.
    Ну и как звучок? наверное, очень сильно отличается в "божественной середине".
  6. Завсегдатай Аватар для ViktKors
    Это картнка - это даже не анекдот (очень люблю ее. Часто показываю, если придется к слову, как совершенно непревзойденный в своем роде пример).
    Тут ИГВИН ратовал за то, что не стоит считать разработчиков аппаратуры идиотами. Так вот глядя на эту картинку возникает две мысли.
    1. Ее рисовала "девочка-дизайнер",
    или
    2. все-таки уважаемый ИГВИН не прав.
    .. ну есть еще одна мысль, на краю сознания. Тот, кто рисовал эту картинку считал идиотами тех, кто будет ее рассматривать
  7. Начинающий Аватар для Alex
    Это картнка - это даже не анекдот.
    А оно всегда такие анекдоты в Сети выискивает. Правда, до рекорда Вали Торнадского все равно не дотянули
    Хотя не, дотянули - там шум АЦП ну ровне -200дБ.
    Я вот только никак не дождусь, когда оно покажат (как неоднократно утверждало), цифровой фильтр на входе АЦП? НАвреное это с ним шум на -200
    А мне пофиг!
  8. Старый знакомый Аватар для Эзотехник
    Ru
    Буквоед нашёлся, блюститель терминологии.
    Я говорил про аналоговый фильтр снаружи SAR и цифровой внутри дельтасигм, с предзвоном и дизерингом.
    Конвергенция аналогового и цифрового домена вносит путаницу, см. рис.
    Шумовая полка. Может и вольтметр(ы) с перестраиваемыми фильтрами вместо АЦП дали такое разрешение.
    В суд подай на MSB за обман.
    Не можешь нарисовать графики сравнения своих ЦАП в одной системе координат - завидуй молча или найми девочку-дизайнера
    Фон -80дБ 50Гц в этой DSD поделке говорит о "выдающемся таланте" разработчика.
    http://forum.vegalab.ru/showthread.p...=1#post2197335
    Pleasurize Music!
  9. Начинающий Аватар для Alex
    Тут терминология не причем, просто ты не понимаешь о чем говоришь.
    ---------- Сообщение добавлено 13:46 ---------- Предыдущее сообщение было 13:44 ----------
    Точно, понимает еще меньше чем я думал
    Наличие аналогового фильтра на входе АЦП обязательно, и не зависит от типа преобразователя, наличие цифрового на его выходе - уже опционально и не обязательно.
    А мне пофиг!
  10. Hate cookies Аватар для abonent007
    Где-то была программка, которая добавляла АЧХ для МП3 по ВЧ, и на спектроанализаторе всё выглядело как настоящий lossless. Вот если она сможет вычислять такие фейки, а не просто чекать спектр на ВЧ, значит годная соофтина
    ---------- Сообщение добавлено 05:16 ---------- Предыдущее сообщение было 04:35 ----------
    Sony PCM 701
    Это ж не "цифровалка" в прямом смысле. Она только оцифровывала и преобразовывала эту цифру в видеосигнал PAL\SECAM, который можно было записать на видеомагнитофон, и с него воспроизводить с видеовыхода через ту же цифровалку. Так сказать для внутреннего потребления. Кто б ей приделал выход SPDIF
  11. Старый знакомый Аватар для Эзотехник
    Ru
    Он там был (copy out), но ещё без упоминания филипса.
    И неотключаемый преэмфазис, может поэтому такие низкие искажения у АЦП (0,005%).
ID:	337868   Нажмите на изображение для увеличения.
    Последний раз редактировалось Эзотехник; 29.01.2019 в 11:05.
  12. Hate cookies Аватар для abonent007
    Что-то мало похоже по схеме на цифровой выход. Хотя данная штука могла ведь использоваться в 80-х годах прошлого века для трансляции звука в цифре вместо тупых телеканалов. И как они не догадались.. Типа абонентский приёмник класса Hi-End, и всё такое
