Страница 1 из 3 123 Последняя
Показано с 1 по 20 из 55
Тема: Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    Маленькая уточка
    Аватар для Black_Panther
    Москва, Бибирево.
    А рожа красная такая Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    В общем, может надо кому.
    Двуполярное питание.
    Я так понимаю, годится для связки с всякими LM/TDA/STK и дискретниками. Ну или встраивать в уси и ресиверы.
    Лично я всеми лапами за питание накала от стабилизатора 7806 а плеч + и - - от 7824 и 7924, но это дело вкуса.
    Мне имхуется что лампочкам типа 6Н3П тут будет комфортнее (ибо вольтаж).
    Сам девайс.
    https://ru.aliexpress.com/item/TR2-6...517133edeX9oVX
    Схема, сканы платки и обведённое в Sprint Layout - вложено.
    Описание от продавца:
    Скрытый текст
    High Lights
    • TR2 tube buffer is based on 6N11 dual triode tube,6N11 have a bulk subsitution include 6DJ8/6922/ECC88/E88CC/CCA,It is very musical tube with excellent extention at high frequency and very low noise,Also great driving ability with higher current than other tube buffer with 6J1 or 6N3. It is designed for audio purpose,The cost of 6N11 is around 10 times to 6J1.Users can use bulk tubes to taste different sounding,Not like many tube buffers.
    • TR2 tube buffer is powered with +- DC power supply from DC22V to DC28V, The advantage of +-power supply is that tube works at wider linear area to get better dynamic and lower distortion, Most tube buffer use single DC power only so the dynamic is not good enough,TR2 has great dynamic. It can share DC power with preamp stage or DAC, Most DACs has dual 15V to 18V AC power so the rectifiered DC voltage is between +-22V DC to +-25V DC, It is not neccessary to add one more power transformer.
    • Filament power supply is 6.3V DC or AC, Users can use LM7806 regulator chip to power 6N11 tube, 10% talerance is allowed for tube.
    • TR2 is in very small size of 64mm*45mm, Can be installed in audio equipments which has not enough room for big tube buffer,It is easy to add TR2 tube buffer into other audio devices.
    • TR2 use dual side PCB board layout, Components can be mounted on two sides except tube socket,Users can install big components on the PCB, It is very flexiable
    • High quality components used on the tube buffer, Resistor is 1W metal film with low temperature drift,The resitor has copper legs which is more better than iron. Input capacitor is ERO and output capacitor is quality MKP caps(brand can be audiophilers or SPIRIT,They are the best in China).
    Specifications
    Tube: 6N11
    Size: 64mm(W) * 45mm(D) * 69mm(H)
    Power Input: (22V-28V)DC -0- (22V-28V)DC, 6.3V DC or AC (pin 4 and 5 of tube socket)
    Gain: 0.9DB
    Output impedance: 200 Ohm
    Нет, пока не собрал и не слушал.
ID:	323169   Нажмите на изображение для увеличения.
    Моя религия:
    STK и дискрет.
    DC Servo - must die.
    Мостовой УНЧ - suxx.
    Импульсные БП - от лукавого.
    За нулями в Кг не гонюсь.
    Старый знакомый Аватар для al2sav
    Черновцы, Украина
    По умолчанию Re: Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    Катодный повторитель с гальванической развязкой входа и выхода можно сделать проще, закоротив R3. Соберете - попробуйте, тогда можно будет и 6Н3П поставить, а пока только 6Н23П.
    Маленькая уточка
    Москва, Бибирево.
    Ох, чую скоро набегут и напишут, что катодный повторитель - кака, а 6Н23П играть не умеет...
    Моя религия:
    STK и дискрет.
    Завсегдатай Аватар для pyos
    C 25 вольтами анодки и током в 1.6мА что угодно будет какой
    Напряжение надо хотя бы на порядок больше, тогда запоёт.
    Маленькая уточка
    Москва, Бибирево.
    Странно,а почему сие ни разу не оказалось какой?
    http://nauchebe.net/2012/08/sxema-gi...reonaushnikov/
    Собирал неоднократно такое, с транзисторами и без - все были довольны...
    Моя религия:
    STK и дискрет.
    В смысле - не оказалась? Самая что ни наесть
    Ну если ничего слаще морковки не есть, то...
    По теме - на такое напряжение разве что стержневая какая лампа или нувистор пойдёт, но с нувисторами я не работал совсем. Стерженьки бывают неплохие, но и им+-25В маловато АФАИР.
    Старый знакомый Аватар для MCA10.5.64
    Благовещенск
    Собирал навесным монтажом и на плате в конце 80-х г. По звуку полное говно. Подключал наушники ТДС-3, ТДС-5, ТДС-7.
    Еще как оказалось!
    Завсегдатай Аватар для fakel
    6Н23П, исправь заголовок
    ---------- Сообщение добавлено 18:11 ---------- Предыдущее сообщение было 18:09 ----------
    По схеме: поднять напругу до честных 120В, в эмиттеры - трансформаторы хотя бы ТВК-110-ЛМ и зазвучит
    ---------- Сообщение добавлено 18:12 ---------- Предыдущее сообщение было 18:11 ----------
    Да не. Тебя не кормить, заиграешь ли?
    Последний раз редактировалось fakel; 30.06.2018 в 16:51.
    Вот, кстати, неплохая идея.
    Маленькая уточка
    Москва, Бибирево.
    Не исключено.
    Одной из причин может быть то, что
    В смысле? По цоколевке туда можно много чего запихнуть.
    Другое дело - вольтажи, да.
    Это филиновскому то?
    Он тут просто для примера был, китайцу, полагаю будет хорошо в стоваттниках где напруга +-50. Ну или выше...
    Ага. В ящщыкЬ!
    Моя религия:
    STK и дискрет.
    Благовещенск
    Black_Panther, В схеме (которая была напечатана В помощь радиолюбителю) была 6н23п, других у меня не было. После первого включения я обрадовался, но потом чуть позже...чем дальше в лес, тем больше ... короче много искажений и грязи. Источник сигнала был катушечный магнитофон Олимп 005с и проигрыватель Арктур 006с. За что эту схему некоторые хвалят, не понимаю до сих пор.
    Последний раз редактировалось MCA10.5.64; 30.06.2018 в 18:40.
    В смысле?
    6DJ8 6922 аналоги нашей 6Н23П, а не 6Н2П. С 6Н2П вообще плохо все. У нее и при 250В ток 2мА против 15 у 6Н23П
    ---------- Сообщение добавлено 19:27 ---------- Предыдущее сообщение было 19:27 ----------
    Это по мне
    ---------- Сообщение добавлено 19:29 ---------- Предыдущее сообщение было 19:27 ----------
    - Музыка ваша - говно!
    - А, мьюзика, ля мьюзика...
    - Ну че ты споришь, я же говорю - говно! (с) "Брат"
    Маленькая уточка
    Москва, Бибирево.
    Даёшь пролётные клистроны!
    Моя религия:
    STK и дискрет.
    ТДС-5 для того времени были просто отличными наушниками, да и сейчас они вполне ничего себе. И уж точно портят звук куда меньше сабжевого буфера
    Маленькая уточка
    Москва, Бибирево.
    У меня есть в наличии две пары ТДС-5М, одна с штекером DIN и переходником на джек, 96 года, с амбушюрами из чего-то жестковатого и одна новенькая, в коробочке, с амбушюрами из кожзама или кожи, непонятно, за столько лет все как новое. Я представляю, как играют пятерки. На малой мощности без тембра баса и верха нет, надо дать газу - всё появляется. Под настроение - неплохие уфки
    Моя религия:
    STK и дискрет.
    Скорее всего, это значит, что усилитель говно они не хватают звёзд с неба, но частотку однозначно не валят.
    Маленькая уточка
    Москва, Бибирево.
    Ага, то есть всё, с чем слушал ТДС-5 : и Sherwood и NAD и Sony ресивер и куча разношерстных STK и TDA7297 плохая и ламповик Cary (попал в микроремонт) тоже плохой оказался...
    Моя религия:
    STK и дискрет.
    Ну это и есть говно, честное, коренное.
    А ламповик с ними даже хороший не споётся. Изодинамике нужно что-то малоискажающее.
    Маленькая уточка
    Москва, Бибирево.
    Правда у всех слушалось без тембра, у некоторых его даже просто отродясь не было и крутить нечего.
    пойду с горя аудионотов с макинтошами и плиниусами прикуплю, без них ведь не видать мне счастья от ТДСок
    ---------- Сообщение добавлено 11:45 ---------- Предыдущее сообщение было 11:44 ----------
    Laconic спелся, но мотороллер был не мой. Усь был чем-то похож на тостер или хлебницу.
    Моя религия:
    STK и дискрет.
