Страница 3 из 3 Первая 123
Показано с 41 по 55 из 55
Тема: Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    Маленькая уточка
    Аватар для Black_Panther
    Москва, Бибирево.
    А рожа красная такая Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    В общем, может надо кому.
    Двуполярное питание.
    Я так понимаю, годится для связки с всякими LM/TDA/STK и дискретниками. Ну или встраивать в уси и ресиверы.
    Лично я всеми лапами за питание накала от стабилизатора 7806 а плеч + и - - от 7824 и 7924, но это дело вкуса.
    Мне имхуется что лампочкам типа 6Н3П тут будет комфортнее (ибо вольтаж).
    Сам девайс.
    https://ru.aliexpress.com/item/TR2-6...517133edeX9oVX
    Схема, сканы платки и обведённое в Sprint Layout - вложено.
    Описание от продавца:
    Скрытый текст
    High Lights
    • TR2 tube buffer is based on 6N11 dual triode tube,6N11 have a bulk subsitution include 6DJ8/6922/ECC88/E88CC/CCA,It is very musical tube with excellent extention at high frequency and very low noise,Also great driving ability with higher current than other tube buffer with 6J1 or 6N3. It is designed for audio purpose,The cost of 6N11 is around 10 times to 6J1.Users can use bulk tubes to taste different sounding,Not like many tube buffers.
    • TR2 tube buffer is powered with +- DC power supply from DC22V to DC28V, The advantage of +-power supply is that tube works at wider linear area to get better dynamic and lower distortion, Most tube buffer use single DC power only so the dynamic is not good enough,TR2 has great dynamic. It can share DC power with preamp stage or DAC, Most DACs has dual 15V to 18V AC power so the rectifiered DC voltage is between +-22V DC to +-25V DC, It is not neccessary to add one more power transformer.
    • Filament power supply is 6.3V DC or AC, Users can use LM7806 regulator chip to power 6N11 tube, 10% talerance is allowed for tube.
    • TR2 is in very small size of 64mm*45mm, Can be installed in audio equipments which has not enough room for big tube buffer,It is easy to add TR2 tube buffer into other audio devices.
    • TR2 use dual side PCB board layout, Components can be mounted on two sides except tube socket,Users can install big components on the PCB, It is very flexiable
    • High quality components used on the tube buffer, Resistor is 1W metal film with low temperature drift,The resitor has copper legs which is more better than iron. Input capacitor is ERO and output capacitor is quality MKP caps(brand can be audiophilers or SPIRIT,They are the best in China).
    Specifications
    Tube: 6N11
    Size: 64mm(W) * 45mm(D) * 69mm(H)
    Power Input: (22V-28V)DC -0- (22V-28V)DC, 6.3V DC or AC (pin 4 and 5 of tube socket)
    Gain: 0.9DB
    Output impedance: 200 Ohm
    Нет, пока не собрал и не слушал.
ID:	323169   Нажмите на изображение для увеличения.
    Моя религия:
    STK и дискрет.
    DC Servo - must die.
    Мостовой УНЧ - suxx.
    Импульсные БП - от лукавого.
    За нулями в Кг не гонюсь.
    Маленькая уточка
    Москва, Бибирево.
    По умолчанию Re: Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    А мы тогда вот такЪ:
    Моя религия:
    STK и дискрет.
    Завсегдатай Аватар для pyos
    Выходное под килом, в зависимости от входной ёмкости схемы может получиться хороший такой ФНЧ. Ну и спектр гармоник для интереса сними хоть тем же спектралабом, хорошо прочищает мозги порталовцам, которые любят говорить об "исчазающе малых высших гармониках ламп"
    С другой стороны, с основной своей функцией - лампизатор - вполне справится.
    С какой целью, понимаешь, создана сия тема?
    Продемонстрировать непроходимую дремучесть топикстартера?
    Удалось, что дальше? Иной раз подумаешь, может лучше чтоб водку пил?
    Маленькая уточка
    Москва, Бибирево.
    Вообще не болею давно что лабом что рмаа. Разве что для интереса на досуге АЧХ глянуть.
    Еще они литиевые батарейки в сетку пихают и фарадные кондеры в питание драйверных ламп...
    В катод стабилизатор HIP5600 просто просится по идее, правда у него 30мА номинальный ток и 40 - пиковый...
    Моя религия:
    STK и дискрет.
    Ну и зря.
    Вот это как раз иногда оправдано бывает. Правда, там физика чуть посложнее 1/2-пи-эр-цэ, и очень далека от того, что автор концепции мегафарад заливает в уши адептам... Ну и очень далеко от оптимального решения тех же проблем, конечно.
    Увы, ты прав. Прошло скоро уж 20 лет, а Лёха по большому счёту всё там же...
    Маленькая уточка
    Москва, Бибирево.
    Ну тут Капитан Очевидность может сообщить, что для того, чтобы желающие могли не кормить Алиэкспресс, а собрать сами, если уж очень надо.
    И да, не у всех есть возможность иметь отдельное высоковольтное анодное.
    ---------- Сообщение добавлено 12:10 ---------- Предыдущее сообщение было 11:55 ----------
    А что не нравится то конкретно?
    http://www.farnell.com/datasheets/30893.pdf
    Моя религия:
    STK и дискрет.
  8. #47
    Иначе исключат из пионеров.
    Не, не исключат. Ты ведь уже выучил "что такое ток базы".
    Значит, нечему волноваться
    ---------- Сообщение добавлено 14:30 ---------- Предыдущее сообщение было 14:25 ----------
    Настоящие порталовцы такого не говорят,- судя по их предпочтениям (винил, ТДА1540, бумага-в-масле, широкополосные говнокланги, кинапы, и т.п.) -, они как раз предпочитают гармоники повыше, причем всех уровней.
    Кому продемонстрировать?
    В этом, как раз ничего плохого нет.
  9. #48
    Маленькая уточка
    Москва, Бибирево.
    Ну мало ли, вдруг я захочу рассчитать ток базы мультиэмиттерного полевого кенотрона
    Моя религия:
    STK и дискрет.
  10. #49
    Петербург
    ...может лучше чтоб водку пил?
    А как же семья?..
  11. #50
    От иного трезвенника семья страдает почище чем от пьяницы.
  12. #51
    Маленькая уточка
    Москва, Бибирево.
    Вообще, мне кажется так: кому зачем-то нужен этот китайский буфер - все нужное в ветке есть.
    Касаемо чем питать накал (постоянкой, переменкой, стабилизировать или нет, от отдельной обмотки, от отдельного тора/не тора) - это вопросы персональной религии.
    Касаемо какую ставить лампу (фашисткий телефункен трофейный, винтаж, N.O.S, современный новодел, вид и тип лампы, ну там октальные, пальчиковые) - тоже.
    Кенотроны, диоды германиевые, диоды обычные, Шоттки, ультрафасты - тем более.
    Относительно анодного. Лично мне для "услышать разницу/покурить ВАХи из даташитов" успешно помогает киловаттный ЛАТР.
    Мой личный вердикт таков: для получения лампового окраса и соответствующих гармоник, то есть если Вы намеренно хотите получить лампизатор - вполне подойдут эти схемы, а именно:
    1. Непосредственно сабж
    2. Филинский девайс: http://nauchebe.net/2012/08/sxema-gi...reonaushnikov/
    3. ЭТО: https://forum.vegalab.ru/showthread....=1#post2509111
    4. Всякие клоны X-10D
    Со своими задачами (окрасить звучание, смягчить немного) - они справляются.
    Не более того. Никаких волшебностей хай-эндных тут не ждите.
    Если хотите полноценный пред без умножителей и маловольтажной двуполярности ( во загнул-то!):
    1. если китайский - Вам сюда: https://ru.aliexpress.com/item/6N3-t...ceBeautifyAB=0
    или сюда: https://ru.aliexpress.com/item/Lusya...ceBeautifyAB=0
    2. если не китайский и сами, то:
    а): Читаем журнал "Вестник А.Р.А,"
    http://www.vestnikara.spb.ru/
    там есть неплохой пред на 6Н23П авторства Lynx (Дмитрий Андронников).
    Ну и много чего еще.
    Еще можно почитать АП и форумы ламповых направлений, выбрать свою персональную религию и годами искать Святой Грааль™.
    б) Гуглим умные книги:
    https://www.google.ru/search?newwind....0.nRj8_xEI53A
    После изучения самостоятельно рассчитываем себе катодный повторитель, SRPP и прочее, что душе угодно. Затем из мешка конденсаторов и вагона разных блоков питания выбираем идеальное для себя сочетание.
    Схемы, справочная инфа по лампам, панелькам - тут много:
    https://www.istok2.com/schemes/
    Вроде даже лампы продают, я пока там не приобретал, не знаю.
    Очень много старых советских ламп есть на Авито (часто можно выбрать год и завод).
    И самое главное, запомните: любая схема обманчива идеальной и самой лучшей на свете схемы лампового буфера/преда - не было, нет и никогда не будет. Ибо каждому своё.
    Да, если кому хочется сразу на колонки:
    а) LM1875+6J1(6Ж1П) - сюды:
    https://ru.aliexpress.com/item/Lusya...6f53464f6BI6Om
    б) Тульские уси Art Audio Lab б/у:
    https://www.avito.ru/rossiya/audio_i...=Art+Audio+Lab
    Конструкторы на вырост, лично у меня такое:
    https://vk.com/don_bastardo?w=wall85384444_4190%2Fall
    (учтите если кто тоже ищет себе m20: зелёный транс (ТАН, трансформатор анодно-накальный) гудит, отвинчиваем и ставим через виброгасители, амортизаторы от автомагнитол, пористую резину, пенополиэтилен или нечто подобное).
    Последний раз редактировалось Black_Panther; 14.07.2018 в 15:59.
    Моя религия:
    STK и дискрет.
  13. #52
    Леха, много букафф.
    Сказать-то чего хотел?
  14. #53
    Маленькая уточка
    Москва, Бибирево.
    Леха, много букафф.
    Примерно это: схема и разработка не моя, не идеал, можно и лучше, я это не продаю, взял поиграться и вывалил сюда, кому интересно - могут копировать или брать за основу, по идее сабж можно и навесным собрать прямо на панельке. Это не хай-энд и не панацея. Так что ко мне никаких претензий, ибо мотороллер не мой
    Моя религия:
    STK и дискрет.
  15. #54
    Новичок Аватар для KoKs
    Господа, а что скажите за этот лот ?
    https://ru.aliexpress.com/store/prod...914650704.html
  16. #55
    Завсегдатай Аватар для Бока
    да, многое могут натворить китайцы , если дать им в руки Микрокап. Даже то, чего нет в учебниках и руководствах по проектированию электронных схем.
    Главное- название позагадочнее. Кто такая та самая Люся? Народ задумается....и купит в задумчивости.
    Такого авангардизьма в лампостроении давно не видел. Взять низкоомную лампочку, спаять на ней катодник, а потом завести оос, чтобы сделать его... еще более катодным. И ладно бы, глубина той оос была бы приличная, но с этими жалкими 5-6 дБ- за что боролись? И зачем?
    Эти китаецкие схемки навевают творчество разных форумных неофитов, пытающихся сочинить что-то более крутое, нежели схемы в книжках
    Последний раз редактировалось Бока; 23.09.2018 в 06:56.
