Показано с 21 по 40 из 55
Тема: Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    Маленькая уточка
    Аватар для Black_Panther
    Москва, Бибирево.
    А рожа красная такая Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    В общем, может надо кому.
    Двуполярное питание.
    Я так понимаю, годится для связки с всякими LM/TDA/STK и дискретниками. Ну или встраивать в уси и ресиверы.
    Лично я всеми лапами за питание накала от стабилизатора 7806 а плеч + и - - от 7824 и 7924, но это дело вкуса.
    Мне имхуется что лампочкам типа 6Н3П тут будет комфортнее (ибо вольтаж).
    Сам девайс.
    https://ru.aliexpress.com/item/TR2-6...517133edeX9oVX
    Схема, сканы платки и обведённое в Sprint Layout - вложено.
    Описание от продавца:
    Скрытый текст
    High Lights
    • TR2 tube buffer is based on 6N11 dual triode tube,6N11 have a bulk subsitution include 6DJ8/6922/ECC88/E88CC/CCA,It is very musical tube with excellent extention at high frequency and very low noise,Also great driving ability with higher current than other tube buffer with 6J1 or 6N3. It is designed for audio purpose,The cost of 6N11 is around 10 times to 6J1.Users can use bulk tubes to taste different sounding,Not like many tube buffers.
    • TR2 tube buffer is powered with +- DC power supply from DC22V to DC28V, The advantage of +-power supply is that tube works at wider linear area to get better dynamic and lower distortion, Most tube buffer use single DC power only so the dynamic is not good enough,TR2 has great dynamic. It can share DC power with preamp stage or DAC, Most DACs has dual 15V to 18V AC power so the rectifiered DC voltage is between +-22V DC to +-25V DC, It is not neccessary to add one more power transformer.
    • Filament power supply is 6.3V DC or AC, Users can use LM7806 regulator chip to power 6N11 tube, 10% talerance is allowed for tube.
    • TR2 is in very small size of 64mm*45mm, Can be installed in audio equipments which has not enough room for big tube buffer,It is easy to add TR2 tube buffer into other audio devices.
    • TR2 use dual side PCB board layout, Components can be mounted on two sides except tube socket,Users can install big components on the PCB, It is very flexiable
    • High quality components used on the tube buffer, Resistor is 1W metal film with low temperature drift,The resitor has copper legs which is more better than iron. Input capacitor is ERO and output capacitor is quality MKP caps(brand can be audiophilers or SPIRIT,They are the best in China).
    Specifications
    Tube: 6N11
    Size: 64mm(W) * 45mm(D) * 69mm(H)
    Power Input: (22V-28V)DC -0- (22V-28V)DC, 6.3V DC or AC (pin 4 and 5 of tube socket)
    Gain: 0.9DB
    Output impedance: 200 Ohm
    Нет, пока не собрал и не слушал.
ID:	323169   Нажмите на изображение для увеличения.
    Моя религия:
    STK и дискрет.
    DC Servo - must die.
    Мостовой УНЧ - suxx.
    Импульсные БП - от лукавого.
    За нулями в Кг не гонюсь.
    Завсегдатай Аватар для pyos
    По умолчанию Re: Китайский ламповый буфер на 6922/6DJ8/6Н2П и т.п.
    пойду с горя аудионотов с макинтошами и плиниусами прикуплю, без них ведь не видать мне счастья от ТДСок
    Достаточно просто хорошего глубокоосника. Макинтоши с аудионотами, кстати, не споются по уже упомянутой выше причине.
    Laconic спелся, но мотороллер был не мой. Усь был чем-то похож на тостер или хлебницу.
    Я знаю этот аппарат, весьма посредственная штука. Во всяком случае, потенциал даже ТДС-5 он не раскроет уж точно, что уж говорить про более хорошую современную изодинамику.
    Завсегдатай Аватар для fakel
    А ламповик с ними даже хороший не споётся. Изодинамике нужно что-то малоискажающее.
    Попробуй 6Н6П с трасформатором
    Пробовал даже Вильямсон на КТ88 и двухтактник на 4131-D3A-2A3. Всё равно не то Хотя на колонки играют эти уси неплохо.
    А вот с несложным композитиком, типа SARP*овского, на удивление хорошо поют.
    Маленькая уточка
    Москва, Бибирево.
    Всё просто: с LOUDNESS ТДСки прекрасно играют, всего хватает.
    ну по крайней мере страшный франкенштейн из 6Н1П+STK459+тонкомпенсированный РГ отлично их "тащит".
    Моя религия:
    STK и дискрет.
    А если без этих эффектов играют плохо - то усилитель говно. С хорошим усилителем они хорошо поют безо всяких тонкомпенсаций.
    Другое дело - "наушниковые" КРГ с учётом дифракций волн об голову и частотозависимой задержкой, как у Назара, но это уже совсем другой уровень - и качества, и сложности.
    Маленькая уточка
    Москва, Бибирево.
    pyos,а почему тогда более десятка остальных ушей играют нормально при прочих равных условиях и без ТК, можно узнать? Наверное, они все тоже говно...
    Моя религия:
    STK и дискрет.
    Точно не знаю, но, скорее всего, взаимная компенсация субъективной "кривизны" усилителя и ушей.
    У изодинамики "кривизна", во-первых, куда меньше, а во-вторых, субъективно "не такая", как у обычных динамических ГГ, плюс чутьё маленькое, что накладывает ограничение на усилитель (т.е. на них плохонький усилитель уже начнёт подкрикивать на том уровне результирующей громкости, где динамики с хорошим чутьём требуют куда меньше мощности, а следовательно - и искажения усилителя слышны меньше).
    Наверное
    Последний раз редактировалось pyos; 03.07.2018 в 13:44.
    Завсегдатай Аватар для sia_2
    Справедливости ради, "кривизна" (амплитудная нелинейность) у изодинамики на самых НЧ часто даже больше, чем у "классики".
    Но выше ~1 кГц как, правило, в плане именно нелинейных искажений выигрыш практически всегда у изодинамики, даже несмотря на существенно худшую чувствительность.
    Проверь стабильность выходного сопротивления усилителя от амплитуды
    Спасибо за информацию, Сергей.
    А насколько низкие НЧ? Я почему-то предпочитал обрезать снизу идущий на наушники (любые) сигнал герц от 60-ти вторым порядком. Скорее по субъективному восприятию, чем по каким-то объективным соображениям.
    ---------- Сообщение добавлено 10:14 ---------- Предыдущее сообщение было 10:07 ----------
    Ты это мне?
    Насколько низкие - "зависит от". На практике где-то ниже 60...80 Гц у большинства изодинамики тупо кончается ход диафрагмы, а она у них в зависимости от прогиба меняет жесткость намного сильнее, чем мало-мальски грамотные подвесы динамических наушников. Ессно, всё зависит от размера, мелкие динамические капсюли - изодинамике не конкурент никаким боком.
    Ты это мне?
    Да
    fakel, ок.
    Доброй ночи.
    Купил на али такую вещьНажмите на изображение для увеличения.
ID:	323587ещё не приехала. Хочу собрать пред на этом буфере, кто нибудь сталкивался. Пишет что клон музикал фиделити х-10.
    Спасибо.
    Маленькая уточка
    Москва, Бибирево.
    Я сталкивался. Оно на лампах 6J1 (6Ж1П), в клоне фиделити стоят 6922 и схема отличается.
    В x-10D стоит два двойных триода, а не пентоды.
    https://ru.aliexpress.com/item/DIY-K...3a9933edMQGsUq
    Схема зверя:
    https://img.mysku-st.ru/uploads/imag.../06/356fe2.png
    Оно требует питания АС12В, то есть ТРАНСФОРМАТОР с одной вторичкой на 12В/1А.
    В цепи питания умножитель напряжения, который работает от ПЕРЕМЕННОГО напряжения.
    Если воткнуть постоянное - не бахнет, работать будет, но неправильно и будут хрипы и искажения.
    Так что заранее озаботьтесь трансформатором.
    Желтые пленочные кондеры лучше потом поменять на китайские же Мундорфы M-CAP - на Али оно красного цвета и зовется там Audiophiler.
    Кондеры супер, если честно. Ссыль на них:
    https://ru.aliexpress.com/wholesale?...udiophiler+mkp
    У этого буфера в комплекте светодиоды подсветки ламп снизу - чисто декоративная функция. В комплекте - синие.
    Будет вот так:
    https://pp.userapi.com/c834403/v8344...GEvnxF3Dp0.jpg
    Поэтому если мало естественного света накала - впаиваем эти:
    https://ru.aliexpress.com/item/100pc...462492054.html
    Моя религия:
    STK и дискрет.
    Никому не показывай.
    ---------- Сообщение добавлено 13:04 ---------- Предыдущее сообщение было 13:03 ----------
    Они и так будут
    Маленькая уточка
    Москва, Бибирево.
    Есть варианты лучше и с двуполярным питанием?
    Они и так будут
    У моего на фото (который на айве лежит) окрас только есть, хрипов нету. Плюс в офисе добавлен еще типичный айвовый окрас из-за её DSP плюс на выхлопе еще Class H (STK419-110). Дома втыкал этот буфер на вход и к своему ламповику ArtAudioLab m.20 (двухтактник на 6П3С) и к Sherwood AX5505 и к STK и к музцентру Samsung MM-A24 (Class D, TDA какая-то).
    Моя религия:
    STK и дискрет.
    1) Зачем там двуполярное питание если на входе и на выходе стоят конденсаторы?
    2) Зачем там двуполярное питание, если там автоматическое смещение и гридлик стоит в минус а не в землю?
    3) Возьми любую схему с однополярным питанием и включи как в этой схеме на двуполярное.
    4) На STK и это сойдет
    Alex,
    5) модифицируй схему предусилителя так, чтобы звук шёл в обход лампы (накал при этом подавать обязательно!), удивись насколько лучше стал звук. Ламповый окрас при этом сохраняется, если лампы с включенным накалом выставлены напоказ.
    Маленькая уточка
    Москва, Бибирево.
    6 стадия:Также выстави напоказ 1-2 пары злых санкенов (можно жженых, но целых визуально). 1216+2922 по-дой-дут! Двух-трёхбуквенную ИМС с платой спрячь внутрь, прикрой лампочками и санкенами. Можно пару К174УН7. Водрузи 1-2 тора, Ватт на 50-60 каждый, прикрой сверху хромированными кастрюлями размером не менее втрое больше торов. Иначе исключат из пионеров.
    7 стадия: лампы замени лампами накаливания, миньонами типа "свеча на ветру".Будет круто. Кастрюли меняем на ТАЗИКИ. Медные. НашЪ ответЪ Ongaku, да. Санкены заменить на брутальные советские старые тиристоры с электрички, вместе с радиаторами оттуда же. Нет, задние фонари с ЭР-2 снимать не надо, хотя...(вот кабина точно лишнее, оставь на месте)
    Моя религия:
    STK и дискрет.
