Наткнулся на информацию о новой линейке динамиков от Вифы, с неодимовыми магнитами. Пищалки 1 дюйм с широким подвесом шелк, алюминий и титан,, маленькие широкополосники и самое интересное - мидвуферы и вуферы. Похожи на иллюминаторы но катушка обычная а не underhung, материал диффузора бумага с волокном, по виду напоминает сисовские с тростником.
Описание от 6-дюймогого из даташита:
The Vifa NE product line has leading-edge transducer technology packaged in a cutting edge, stylistic design. The woofers in this product line feature an innovative cast aluminium basket design which minimizes acoustic reflections inside the driver, through large basket windows and sculpted basket spokes. The basket also is designed to act as a highly coupled heat sink to the Neodymium-Iron-Boron magnet (NdFeB) motor, so as to improve power handling capacity. An additional heat sink is available to provide extra thermal protection if needed. The cone and dust cap are constructed of natural wood fiber material with proprietary coating formulas & processes, so as to yield high clarity products. The cone designs also utilize pentacone technology for improved frequency response. The voice coil bobbin is titanium, for improved performance. The FEA-designed motor features copper caps to minimize inductance and extend performance to high frequencies. Rounding out the design is a 4-way terminal block connector, for ease of electrical connection.
Вся информация пока - Рreliminary, на собственном сайте - информации мало. Поэтому вот несколько ссылок:
http://www.audiokit.it/itaeng/Altopa.../VIFA/Vifa.htm
http://www.madisound.com/catalog/pro...oducts_id=8695
http://www.madisound.com/catalog/pro...oducts_id=8696
http://www.madisound.com/catalog/pro...oducts_id=8699
http://www.madisound.com/catalog/pro...oducts_id=8701
http://www.madisound.com/catalog/pro...oducts_id=8703
http://www.madisound.com/catalog/pro...oducts_id=8704
http://www.madisound.com/catalog/pro...oducts_id=8705
http://www.madisound.com/catalog/pro...oducts_id=8700
на мадисаунде их пока нет в наличии но зато хорошие фотографии.
Цены (на странице модели могут быть не указаны, но если искать через поиск - то такие):
NE19VTA-04 Vifa NE19VTA, 3/4" Aluminum Dome Tweeter, 4 ohm $24.15
NE25VTA-04 Vifa NE25VTA, 1" Aluminum Dome Tweeter, 4 ohm $28.80
NE85W-04 Vifa NE85W, 2.5" Fullrange Driver, 4 ohm $27.40
NE123W-04 Vifa NE123W, 4" Woofer, 4 ohm $65.15
NE149W-04 VIFA NE149W-04, 5.25" Woofer, 4 ohm $92.55
NE180W-04 Vifa NE180W, 6.5" Woofer, 4 ohm $98.35
NE225W-04 Vifa NE225W, 8" Woofer, 4 ohm $137.30
NE265W-04 Vifa NE265W, 10" Woofer, 4 ohm $174.05
NE315W-04 Vifa NE315W, 12" Woofer, 4 ohm $202.65
