Показано с 1 по 20 из 61
Тема: Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    Перфекционист затейник
    Аватар для cka3o4nuk
    Украина Николаев
    По умолчанию Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    http://www.zaphaudio.com/SB12.3/
    INTRODUCTION
    This is a large floor standing three way system using SB Acoustics drivers. We use the SB29RDC-C000-4 ring radiator dome tweeter, affectionately known as the dimple dome. For the mids, we use a pair of SB15NRXC30-8 5" midwoofers, and finally a SB34NRX75-6 12" woofer to handle the low end. These are all drivers with very high performance at a good price, and the build quality is excellent. The midrange and tweeter are fully tested and reviewed in the comparisons elsewhere on this site, and the 12" woofer test results are posted below.
    Small designs are a dime a dozen, but very large multi-way designs are not so common. I teamed up with Madisound to "go big" in a big way and this project is the result. The world is full of tiny designs that might find their way to a small shelf, hidden between a plant and some books. This is a design for the other end of the home decor spectrum - when a visitor walks into the room, they can*t help but say "holy crap, look at those speakers!"
    There were a couple of directions we could have gone with this selection of drivers. It came down to the decision between front mount and a side mount woofer. Those two layouts require different crossovers so we had to pick one. We decided on the layout that could be described as "classic wide". These are much more than party speakers however. The design is high end throughout and I can*t even fathom how much a system like this might cost in the retail world. If I had to take a guess, I*d say somewhere in the 5 digit range. While this system is still not exactly cheap, DIY brings the cost down to be much more affordable.
    думаю стоит собирать
ID:	68829   Нажмите на изображение для увеличения.
    there is no going back...
    (c) Tony Gee
    По умолчанию Re: Новая разработка Запха 3х полоска с 12шкой на SbAcoustics
    Обычная АС.Ничего особенного.
    Украина Николаев
    готовых проектов более чем 2х полосок на сб акустиксе мало
    цена на эти дины привлекательна.
    (c) Tony Gee
    Москва, Бун.Луга
    Я бы не стал. Больше похоже на сабвуфер+d*appolito.
    С17 на середине не нравится.
    old chap Аватар для subsonic
    Сабвуфер + д"Апполито будет интересней чем эта конструкция ...
    Москва, Бун.Луга
    Я на это и намекал .
    Частый гость Аватар для dolin
    Питер
    Тока где ее посмотреть можно
    cka3o4nuk, чего хоть сам автор про нее говорит,как играет хоть?
    Частый гость Аватар для Ясный Сокол
    6ка сб звучит очень приятно. Пищик с пипкой в середине их я тоже припас .
    А как вам такое? -
    "I*ve never heard of ground plane measurement before, what is it?
    Very simply, the mic is placed on the floor. This removes the floor bounce reflection and allows accuracy much lower in frequency. The distance to the side walls become the limiting factor. This method works best on a hard floor, but good results can also be had on carpet if you place the mic on a large board. The only ground plane measurement in this design was the lower half of the woofer response, which was merged to a 1 meter on axis curve of the woofer. This combines the frequency ranges where each type of measurement is the most accurate. The mids and tweeter were measured with more conventional techniques. "
    Москва, Бун.Луга
    А 100кг-вая акустика подвешивается за люстру.
    На сб-акустикс еще такой "хамелеончик" появился двухполосный:
    http://www.zaphaudio.com/DLR/
    Завсегдатай Аватар для Dmitr_RE
    в смысле SB17NRXC35-8?
    Добавлено через 5 минут
    Я бы не хотел судить по фото о звуке как остальные, но звучать может очень даже весело.
    Последний раз редактировалось Dmitr_RE; 27.11.2009 в 01:57. Причина: Добавлено сообщение
    Москва, Бун.Луга
    Нет, электролитический конденсатор на 600мкФ.
    Завсегдатай Аватар для Yurgen
    Из Замкадья
    cka3o4nuk, я бы не стал это чудо собирать, хотя возможно для домкино сгодиться, но все-равно дизайн ящиков уродский. А для музыки даже десятка от СБ тяжеловата.
    Я бы сказал - интересные колонки, но не для всех. Что-то типа "какими должны были быть С90". Толково, широко, но без претензий
    с уважением Александр
    Из Замкадья
    Вместо двенашки десятку SB поставить, корпус сделать узким, переднюю морду с закруглениями, НЧ сбоку и будет уже намного лучше.
    Регистрация не подтверждена Аватар для DECEMBER
    Литва, Каунас
    Просто наклоняется вперёд.
    Завсегдатай Аватар для Ale
    г.Орёл, РФ
    Вона где дают
    Особенно приятно, что System sensitivity: 92 dB
    а у "SB Acoustics SB34NRX75-6 12" Woofer" Sensitivity (2.83V/1m) 91 dB
    Украина Николаев
    нч сбоку от 400гц будет играть .. как интересно - в топку.
    (c) Tony Gee
    Из Замкадья
    Есть такая проблема, от 400 это будет высоковато, возможны проблемы с мидбасом, а если опустить может появиться другая проблема с накачкой. Но если эту проблему решить то получим в результате очень хорошую локализацию источников. Подобная АС есть у моего знакомого.
    ★★★★★✰ Аватар для s3tup
    Недоступно
    И решается эта проблема активным разделом, возвращая к дАпполито+саб...
    Сюда-бы легкий прошный мидбас, раздел на 400-500, и колоночка бы заиграла. двенашка сб - это средненький сабик...
