вопрос по капсулям - но мне для голоса чтоб среднетерпимо звучал мужской голос, а не для замеров или прозаписи...
есть питание 5v и капсули - Panasonic wm-34 и Panasonic wm-54 - если найти Panasonic wm-60/61, качество голоса сильно подскочит ?
...даташиты смотрел, графон отличается толька выше 25к, а текст фиг поймешь буквально
также вопрос - wm-54 почемуто намного тише чем 34 - по дате вроде нет такой сильной разницы, это капсуль сдох или перегрузка вольтажа питания ?
----------------- wm-34 ( 34j5x )
* Useful for almost any type telephone and other applications
* Low operation voltage of 1.0V to 10V (2M-034D type)
* Microphone with pins for PCB (WM-034B/034DB type)
Sensitivity See next page (0dB = 1V/pA, 1kHz) --- 38±3dB >> 46±3dB --- 36±2dB >> 44±2dB
Impedance Less than 2.2 kOm [1.5 kOm]
Directivity Omnidirectional
Frequency 20–16,000 Hz
Max. operation voltage 10V
Standard operation voltage 4.5V [1.5V]
Current consumption Max. 0.8mA [0.3mA]
Sensitivity reduction Within –3dB at 3V
[(M.H.): Within –3dB at 1V]
[(P.R.U.): Within –2dB at 1V]
S/N ratio More than 60dB
----------------- wm-54 ( 54j5m )
* High-cost performance, electret condenser microphone cartridge
* WM-52B series are low-voltage, 1.5V operation microphones and suitable for all telephone applications, intercoms, and computers
* WM-54B series are low-voltage 2.5V operation microphones and suitable for tape recorders, telephone devices, and toys
Sensitivity See next page (0dB = 1V/pA, 1kHz) --- 40±2dB >> 44±3dB --- 42±2dB >> 46±3dB
Impedance Less than 3.0 kOm [2.2 kOm]
Standard operation voltage 1.5V [2.5V]
Current consumption Max. 0.3mA [0.6mA]
Sensitivity reduction Within –3 dB at 1.1V [2V]
----------------- wm-60
Features
* Small microphones for general use
* Back electret type designed for high resistance to vibrations
Sensitivity – 44±5dB (0db = 1V/pa, 1kHz) --- 42 ±3dB // 44 ±3dB // 46 ±3dB
Frequency 20–20,000 Hz
Standard operation voltage 2V
Current consumption Max. 0.5 mA
Sensitivity reduction Within –3 dB at 1.5V
S/N ratio More than 58 dB
----------------- wm-61
* Small microphones for gener al use
* Back electret type designed for high resistance to vibrations, high signal-to-noise ratio
* High sensitivity type
* Microphone with pins for flexible PCB (WM-61B type)
Sensitivity –35±4dB (0db = 1V/pa, 1kHz) --- 35 ±4dB
S/N ratio More than 62 dB
у 34 и 54 пустая строка Sensitivity - в дате вместо цифр фраза "See next page" и сверху списки буквенных индексов и значений
