Страница 10 из 11 Первая ... 891011 Последняя
Показано с 181 по 200 из 204
Тема: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Перфекционист затейник
    Аватар для cka3o4nuk
    Украина Николаев
    По умолчанию ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    ASUS just released an audio precision report of its latest product Xonar Essence STX. (
    According to ASUS, the yet-to-be-release audio product Xonar Essence STX is “world’s first onboard headphone amp 600ohms headphone with <100dB THD+N”. What’s more, Xonar Essence STX isolated power sources for headphone output and normal audio output. The whole card is using Nichicon capacitors which is called “fine gold”. We don’t know the release date of the card, but it will become another expensive enthusiast audio product.
    Craving for the clearest audio source to support your precious headphone and speakers? Then let Xonar Essence STX amaze you. Being the world’s first audio card to achieve 124dB in signal-to-noise ratio, and capable of driving headphone with highest impedance under lowest 100dB distortion, your only concern will be hard to stop the heavenly music playback from Xonar Essence STX.
    Designed in Essence
    Perfectly sealed by improved EMI shield, Xonar Essence STX’s analog output path generates the purest audio ever from a sound card -124dB signal-to-noise ratio and 0.0003% distortion.
    Fine-selected Components
    With premium-quality digital-to-audio converter and audio-specific capacitors selected, Xonar Essence STX provides <10~90kHZ frequency response and 124dB dynamic range for your unlimited pleasure.
    Shines your beloved headphones
    Drives up to 600ohms headphones with less than 100dB distortion, the built-in headphone amp supports every available headphone in the market with unbelievable audio quality.
  2. #181
    По умолчанию Re: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Цитата Сообщение от МихаилNegative Посмотреть сообщение
    Сравнил встроенный THS6020 и мою плату от vidalgo ths6012+ada4726 разница пока маленькая
    Может, всё-таки ths6012+ada4627?
  3. #182
    Частый гость Аватар для levgy
    а встроенный наверно TPA6120
  4. #183
    Старый знакомый Аватар для МихаилNegative
    Ижевск Россия
    Да наврал Все верно TPA6120, вненший - ths6012+ada4627
    ---------- Добавлено в 18:06 ---------- Предыдущее сообщение в 18:00 ----------
    Цитата Сообщение от GruWer Посмотреть сообщение
    Все равно внешний усилок на AD815 лучше будет.. Купил карту, вставил подключил уши к встроенному усилку слушаю что-то не так, какая-то сухость\жесткость, подключил к AD815 - совсем другое дело, звук стал мягче и мощнее. Пока разницу между креативом x-fi не замечаю, ну только что грязь пропала. Наверное что бы ощутить всю разницу, нужно немного погодя послушать снова креатив)
    Xonar Essence ST единственная карта, с которой стало приемлемо слушать Grado sr225. Но только после весьма сертезных изменений в ней. В i/u opa827, в сумматоре сток, но как то не нравится мне 4562 в связке с опа827, считаю что 4562 ограничивает возможности опа827, плюс перепаенные резисторы под 1в RMS, что существенно смягчает звук. Сравнивал с Esi Juli@, Кративами разными, Esi Maya44.
  5. #184
    В i/u opa827, в сумматоре сток, но как то не нравится мне 4562 в связке с опа827.
    I/U - OP42, cумматор - LME49720(2). Все ОУ - металлический корпус.
    Последний раз редактировалось EDDiE; 29.08.2011 в 22:18.
  6. #185
    Ижевск Россия
    EDDiE что посоветуешь к опа827 в сумматор? я вот думаю докупить еше опа827 что бы везде стояли, или лучше другим оу их скомпенсировать, хотя на слух сложно сказать что надо компенисровать у опа827 в роли i/u
    ---------- Добавлено в 00:22 ---------- Предыдущее сообщение в 00:19 ----------
    Сейчас кажется что иногда вокал теряется за басом и вч, как бы съедает слова. В основном по началу было так, потом раз сто карту снимал шунтировал по разному и придя к минимальному уровную гармоник успокоился.
    ---------- Добавлено в 00:25 ---------- Предыдущее сообщение в 00:22 ----------
    LME49722 пока нету на элитане, по идее 4562 достаточна прозрачна, может это опа827 так излишне баса дает, хотя для Градо это больше плюс чем минус, но сч для градо более важен, тк их фишка в невероятно эмоциональном вокале.
  7. #186
    Новичок Аватар для MRM74
    I/U - OP42, cумматор - LME49722. Все ОУ - металлический корпус.
    В обвязке ничего не меняется?
  8. #187
    Для ОР42 можно сделать примерно так, как показано на схемах LYNX D35, D29, D47 и даташитах на сами ОР42 и LME49722.
  9. #188
    Заказал 2шт AD8397 и десяток LME49722 - ждёмс, всё в соике
  10. #189
    Цитата Сообщение от levgy Посмотреть сообщение
    Заказал 2шт AD8397
    А эти куда?
  11. #190
    Заказал 2шт AD8397
    А эти куда?
    хочу попробовать в I/U, у них ток очень приличный, потом можно и на ушки прикрутить если что
    http://www.analog.com/static/importe...ets/AD8397.pdf
    http://www.lossy.ru/forums/showthread.php?t=1438
    - думал об этом, даже есть описание где ОУ JRC5532 был заменен на AD 8397, по словам автора, карта тут же отреагировала на смену операционника увеличением низких частот и повышением детализации -
  12. #191
    Они туда не пойдут по нескольким причинам:
    1) Относительно большой Iвх
    2) Низкое Rвх
    3) Скорее всего отсутствуют резисторы в эмиттерных цепях входного каскада.
  13. #192
    А как же LM6172 - Iвх 1.2-3мкА, некоторым нравиться, да и в тестах приличные результаты,
    наверно главное что бы входное было постоянным, не смотря на то что низкое?
  14. #193
    Ей обвязку надо менять.
  15. #194
    у неё ещё вторая гармоника выше третьей, может быть мягкое звучание
    ---------- Добавлено в 23:00 ---------- Предыдущее сообщение в 22:57 ----------
    придёт - попробуем - узнаем - сообщим,
    обвязка и так пересчитана под 1в, резюки в I/U уменьшены до 390ом и кондёры увеличены примерно в 2 раза - посмотрим что выйдет,
    придут наверно месяца через 1,5 (Элитан)
  16. #195
    Старый знакомый Аватар для scarp
    С-Петербург/ Вырица
    2) Низкое Rвх
    Для I/U не имеет никакого значения.
    Моя система: AMD K2-350->USB->China transmitter->Альпинист-2(все кандёры заменены на Black Gate)
    Питер: http://www.liveinternet.ru/community/1148378/post125261680/
  17. #196
    Ижевск Россия
    LM6172
    Первое впечатление вобше не к месту, потом как то притерлась (1в рмс) слушал месяц полтора, но в итоге ушел от нее. Сейчас пытаюсь раскусить в чем прикол опа827, первое впечатление у звука появилось третье измерение, позже все так же как раньше - красиво и детально. Но есть то, что не дает покоя с ними, пока не понял что это.
  18. #197
    scarp,
    что вы думаете по поводу AD8397
  19. #198
    EDDiE, А op42 в сумматор не пробовали?
  20. #199
    У ОР42 резики во входных каскадах, что очень положительно сказывается в её устойчивости и переносимости ВЧ мусора по входу. Поэтому, её хорошо в I/U ставить. В сумматор не пробовал - попробуйте.
  21. #200
    С-Петербург/ Вырица
    levgy, не применял. По идее, должны быть очень хороши в низковольтном ушном усилителе.
    Для I/U в ЦАПе крайне важна линейность входного каскада ОУ в условиях ВЧ помех(особенно для дельта-сигма ЦАПов), а таких параметров не приводят в даташитах. Только экспериментальным путем, надо пробовать. Андронников приводил измерения для некоторых типов ОУ.
    У AD8397 настораживает не апериодический отклик на ступеньку.
