Страница 3 из 11 Первая 12345 ... Последняя
Показано с 41 по 60 из 204
Тема: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Перфекционист затейник
    Аватар для cka3o4nuk
    Украина Николаев
    По умолчанию ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    ASUS just released an audio precision report of its latest product Xonar Essence STX. (
    According to ASUS, the yet-to-be-release audio product Xonar Essence STX is “world’s first onboard headphone amp 600ohms headphone with <100dB THD+N”. What’s more, Xonar Essence STX isolated power sources for headphone output and normal audio output. The whole card is using Nichicon capacitors which is called “fine gold”. We don’t know the release date of the card, but it will become another expensive enthusiast audio product.
    Craving for the clearest audio source to support your precious headphone and speakers? Then let Xonar Essence STX amaze you. Being the world’s first audio card to achieve 124dB in signal-to-noise ratio, and capable of driving headphone with highest impedance under lowest 100dB distortion, your only concern will be hard to stop the heavenly music playback from Xonar Essence STX.
    Designed in Essence
    Perfectly sealed by improved EMI shield, Xonar Essence STX’s analog output path generates the purest audio ever from a sound card -124dB signal-to-noise ratio and 0.0003% distortion.
    Fine-selected Components
    With premium-quality digital-to-audio converter and audio-specific capacitors selected, Xonar Essence STX provides <10~90kHZ frequency response and 124dB dynamic range for your unlimited pleasure.
    Shines your beloved headphones
    Drives up to 600ohms headphones with less than 100dB distortion, the built-in headphone amp supports every available headphone in the market with unbelievable audio quality.
    Частый гость Аватар для Vladimir1970
    По умолчанию Re: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Цитата Сообщение от Dmitry 60 Посмотреть сообщение
    Похоже реле коммутирует сигнал от цапа либо на линейный Ус либо на телефонный по входу. Как-бы не very good.
    Именно так и есть. Что плохого?
    Новичок Аватар для Dmitry 60
    ДВ
    Уж больно сигнал слаб для контактиков
    Новичок Аватар для leninSama
    обидно столько времени прошло и ни кто ни чего путного про эту карточку не написал(
    завтра будет... лучше
    Ну вот и до хобота карточка доехала
    http://www.ixbt.com/multimedia/asus-stx.shtml
    хороший обзор... но хочется самому послушать карту( А это к сожалению практически не возможно((((
    Маленькая уточка Аватар для Black_Panther
    Москва, Бибирево.
    Эх, ну почему этот Ксонар не выносной?В смысле, не внешний?
    Сижу пока с внешней Creative SB Extigy,устраивает всем, но вот драйверов для нее под 64-битную хрюшу а также под Висту и Виндовс7 ( по сути та же Виста,ставил уже поиграться) нету. Хотя примерно уже месяц зуб точу на Ксонар, правда пока что финансы спели романсы из-за покупки нового монитора, блока питания и видеокарты.
    Моя религия:
    STK и дискрет.
    DC Servo - must die.
    Мостовой УНЧ - suxx.
    Импульсные БП - от лукавого.
    За нулями в Кг не гонюсь.
  8. #47
    Сижу пока с внешней Creative SB Extigy,устраивает всем.
    У внешних звуковух есть тормоза по шине USB, как писалось о проблеме на ixbt?
  9. #48
    Москва, Бибирево.
    Может и есть. Пока не замечал. В чем они должны проявляться?
    Моя религия:
    STK и дискрет.
  10. #49
    Новичок Аватар для tonalex
    Никак не добьюсь , кто-нить пробовал задействовать внешнее питание ?
    А то все опера , опера ... Чего-уж проще +12 и +5 В через стандартный разьем .
  11. #50
    Новичок Аватар для amvplus
    Вот это уже придумано...осталось проверить
Название:	Отдельный блок питания на звуковую карту.jpg
  12. #51
    Частый гость Аватар для levgy
    там ещё преобразователь в -12в для оперов, его ещё бы заменить на обычное питалово
  13. #52
    Старый знакомый Аватар для vladimir_ar
    Украина, Кременчуг
    Пробовал Creative X-Fi 5.1 USB...
    Ну что сказать (сравнивал на тот момент с Creative Live! 5.1 Digital c операми на выходе OPA2727)... По звуку без разницы.
    А по поводу работы - тормоз редкий. И еще такой глюк был - при переводе карточки в 24/192 начинался пердеж.
    Сейчас у меня XONAR DS - намного лучше по звуку и без описанных глюков.
    Кстати, какими напряжениями питается опер на линейном выходе XONAR? А то у меня такая конфигурация компа (лаптоп), что к карте не добраться, а подпаивать провода, чтоб померять - не очень хочется. Хочу поставить OPA2727, но у них питание +/-5,5В максимальное.
  14. #53
    в ASUS Xonar Essence STX говорят +-12в
  15. #54
    Старый знакомый Аватар для Слава К
    Точно.
  16. #55
    Вот думаю взять такую и не париться ни с какими усилителями для наушников и цапами.
    Руки только чешутся сделать питание от отдельного блока со стабилизатором и транформатором на торе..
  17. #56
    Украина Николаев
    зачем если все помехи все равно пролезут через цифирь
    there is no going back...
    (c) Tony Gee
  18. #57
    Старый знакомый Аватар для Velzivul
    Россия Вологда
    во во земли то общие, пробовал ставить внешнее питание на свою 1212m PCI: что по замерам, что по звуку никакой разницы. Нужно гальванически отвязывать карту от компа, что проблематично
    Windows 10 x64 > Foobar2000 v 1.3 > ASIO > EMU1212m PCI (AD8066) > M-Audio BX-8 D2 (AD823)
  19. #58
    Новичок Аватар для avsaler
    Кто нибудь сравнивал звучание Xonar ST (STX) c другими карточками, например EMU 1212 или Dr DAC?
  20. #59
    Подобная тема уже существует, но владельцев "и того и того" не так много! https://forum.vegalab.ru/showthread.php?t=32326
    На карте стоят ужасные ОУ (в I/U, JRC2114), но так, как их можно заменить - это не проблема! После замены этих оперов на THS4062 звук значительно улучшился (детализация, натуральность, энергетика), а ведь есть еще более достойные кандидаты!
  21. #60
    38RUS
    есть карточки на воспр 192 кгц дискретизация?
