Страница 11 из 11 Первая ... 91011
Показано с 201 по 204 из 204
Тема: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Перфекционист затейник
    Аватар для cka3o4nuk
    Украина Николаев
    По умолчанию ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    ASUS just released an audio precision report of its latest product Xonar Essence STX. (
    According to ASUS, the yet-to-be-release audio product Xonar Essence STX is “world’s first onboard headphone amp 600ohms headphone with <100dB THD+N”. What’s more, Xonar Essence STX isolated power sources for headphone output and normal audio output. The whole card is using Nichicon capacitors which is called “fine gold”. We don’t know the release date of the card, but it will become another expensive enthusiast audio product.
    Craving for the clearest audio source to support your precious headphone and speakers? Then let Xonar Essence STX amaze you. Being the world’s first audio card to achieve 124dB in signal-to-noise ratio, and capable of driving headphone with highest impedance under lowest 100dB distortion, your only concern will be hard to stop the heavenly music playback from Xonar Essence STX.
    Designed in Essence
    Perfectly sealed by improved EMI shield, Xonar Essence STX’s analog output path generates the purest audio ever from a sound card -124dB signal-to-noise ratio and 0.0003% distortion.
    Fine-selected Components
    With premium-quality digital-to-audio converter and audio-specific capacitors selected, Xonar Essence STX provides <10~90kHZ frequency response and 124dB dynamic range for your unlimited pleasure.
    Shines your beloved headphones
    Drives up to 600ohms headphones with less than 100dB distortion, the built-in headphone amp supports every available headphone in the market with unbelievable audio quality.
  2. #201
    По умолчанию Re: ASUS Xonar Essence STX, хорошая звуковая карточка с SNR до 124dB
    Вкладывать в переделку этой ЗВ стоимость хорошего ЦАПа не имеет никакого смысла.
    Лучше вывести I2S с компа на отличный ЦАП и слушать музыку через него.
    Купив эту карту после Creative X-Fi Platinum ужаснулся звуку ASUS Xonar Essence ST идущему на колонки.
  3. #202
    Частый гость Аватар для GruWer
    А что скажете по поводу цитаты из обзора на ф-центре:
    Сразу после установки Xonar Essence в компьютер, с первых же прослушанных музыкальных композиций (XRCD версия альбома Judas Priest «Wings of Destiny») стало понятно, что я имею дело с очень хорошо звучащим источником. Но любопытство заставило меня подключить усилитель не к линейному выходу карты, а к гнезду для наушников, и тут меня ждало настоящее открытие — звук оказался заметно прозрачнее и четче! Дальнейшее сравнение звука с двух выходов подтвердило первое впечатление: линейный выход, представленный в данном случае разъёмами RCA вместо обычных для звуковых карт мини-джеков, звучит как-то смазано. Нет, он не крадёт детали и не портит звуковую сцену, просто играет чуть тягуче и немного размывает мнимые источники звука, особенно высокочастотные. Это заметно в сравнении с выходом для наушников
    Парадоксально, но выход для наушников оказался качественнее линейного выхода, намного перекрыв паспортные характеристики по искажениям. Следовательно, неожиданно высокий уровень искажений на линейном выходе вызван не недостаточным качеством линейного входа, а иными причинами. Вероятнее всего, виноваты резисторы обратной связи, поскольку замена операционных усилителей абсолютно никак не повлияла на измеряемые характеристики.
  4. #203
    GruWer, если Ваш вопрос мне, то:
    У каждого своё представление о хорошем звуке. Скажу только, что колонки не подсоединял в наушниковый выход, но слушать её не переделанную можно только через наушники с наушникового выхода. Там звук лучше, чем на линейном выходе карты.
  5. #204
    Старый знакомый Аватар для МихаилNegative
    Ижевск Россия
    EDDiE Какие минимальные доработки надо проводить что бы с линейника получить ту же прозрачность что и в наушниковом. 1в RMS только смягчает "компьютерный" характер звучания. Различные варианты шунтирования на прозрачность считаю не влияют. Замена в i/u на более приличные оу это изменение общего характера. А вот на что заменить в сумматоре надо думать. тк 4562 достаточно хорошо, я пока лучше не нашел на роль сумматора.
