Показано с 1 по 10 из 10
  1. Частый гость
    Аватар для VasilyN
    Москва, РФ
    По умолчанию Цифровой выход в iPod?
    Тут знатная фирма Wadia анонсировала док-станцию для iPod http://www.wadia.com/products/170i/1...sport_home.htm , где за небольшую плату обещают байпасс цифрового выхода айпод*а! Я был твёрдо уверен, что на разъём iPod никакая "цифра" не выводится, но бодрый пресс-релиз Wadia утверждает обратное:
    CES ’08 – Venetian Room #30-236
    Wadia Digital Debuts The iTransport
    Enabling Full Resolution Digital Output From iPod® Players
    -- iTransport Delivers Bit-Perfect Digital Audio
    From Files Stored on All Currently Available iPod® Players --
    LAS VEGAS, NV, January 7, 2008 – Wadia Digital, a high-end audio company dedicated to the development of digital audio technologies, is demonstrating the market’s first digital player dock to retrieve a direct digital signal from an iPod®. As a result, the audio signal remains pure and unadulterated, providing CD-quality resolutionfrom full-resolution file formats such as .WAV and .m4a (Apple® Lossless).
    The iTransport (SRP: $349), which is certified Made for iPod®, turns any currently available iPod player into a high-end media server by providing a bit-perfect digital audio output to an audio/video system, bypassing the player’s internal D/A conversion and output stage. Subsequently, the audio signal remains clean and unadulterated throughout the path. The iTransport is compatible with all currently available (Q1 2008) iPod players, as well as iPhone® and iPod Touch® models.
    “Until now, there has been no real bridge between the convenience of an iPod and the high-end audio listening experience,” commented John W. Schaffer, President, Wadia Digital, Inc. “The goal of making the player a true high-end media server has been hampered by the need to send the digital signal through a portable player’s D/A converter rather than that of a high performance audio system.
    “Instead, we designed iTransport to bypass the player’s converter and output stage altogether. When used with an iTransport, the iPod becomes a digital music source equal to some of the finest sounding transports in the high-end audio market.”
    D I G I T A L I N T U I T I O N
    Along with turning an iPod into a high-performance audio server, iTransport is one of the first such products to access video content stored on currently available iPods. Similar to the audio section, the video signal is made available via high performance component outputs that provide up to DVD-quality video.
    The iTransport measures 2” x 8” x 8” (H/W/D), making it an easy addition to most racks and entertainment centers. Wadia incorporates a bit-perfect S/PDIF digital audio output and high-resolution component digital video output, as well as analog audio and video outputs for
    easy connection with most audio/video systems. iPod players are charged while in the dock, and can be operated via Apple’s standard IR remote control. (Not included with iTransport.)
    Wadia Digital’s iTransport will ship in February 2008, and will be available at select high-end audio specialists and the Wadia Digital web site – Wadia Home Page.
    iPod is a registered trademark of Apple Computer. This product has been designed specifically to work with iPod
    and has been certified by the developer to meet Apple performance standards.
    Никто не разбирался, что-же творится на разъёме iPod, неужто там действительно цифра "бродит"?
    Велика сила индуктивного мышления
  2. Новичок Аватар для ssk16
    По умолчанию Re: Цифровой выход в iPod?
    http://pinouts.ru/PortableDevices/ipod.shtml Вот распиновка разъема Иподов. Вроде как вижу там слово ФиреВире. Оно?
  3. Частый гость
    Аватар для VasilyN
    Москва, РФ
    Я так понял FireWire для общения с компом (закачки контента). Может, 12 штырёк - Tx ipod sending line, Serial TxD ?
  4. Регистрация не подтверждена Аватар для Kompros
    Ничего-ничего, найдется герой, пришлепнет к 21-му контакту переменник и пойдет осцой искать spdif/i2s, глядишь, может чего и сыщет.
  5. Частый гость Аватар для 24x96
    Глубоко сомневаюсь, что он там что-то сышет - в лучшем случае найдет там RS-232!
    Проще всё прочитать с асинхронного интрейфейса и правильно воспроизвести.
    А вообще, что использовать iPOD, что внешний жесткий диск - концептуально большой разницы нет.
  6. Регистрация не подтверждена Аватар для Kompros
    Так-то да, но если есть выбор, то, ИМХО, уж лучше без механики.
  7. Частый гость Аватар для 24x96
    Это один из аудиомифов, что без механики лучше. Если использовать для передачи асинхронные интерфейсы (USB, Firewire, Ethernet. WiFi и т.д.), то абсолютно по барабану с какого носителя вы читаете эти данные. Главное - чтобы они не искажались и не опустошался буффер на принимающей стороне. В результате качество будет зависеть только от приемного устройства (в рассматриваемом вами случае Wadia).
  8. Регистрация не подтверждена Аватар для Скиф
    Донецк
    может чего и сыщет
    А может и
    http://www.yaplakal.com/uploads/post...3151668476.jpg
    Сперто отсюда: http://forum.vegalab.ru/showpost.php...postcount=3838
    Как-то же управляют автомагнитолы айподом. Значит есть такой интерфейс.
  9. Регистрация не подтверждена Аватар для Kompros
    24x96
    Не знаю о каких мифах речь, но механика банально акустически шумит (типа, ночером слышно, как она, механика, шевелится) и шибко чувствительна к мех.воздействиям.
    Сугубо ИМХО.
  10. Частый гость Аватар для 24x96
    24x96
    Сугубо ИМХО.
    С тем, что механника шумит трудно не согласится. А что касается механических воздействий - то ничто не вечно под луной!
