The lower of the two drivers has a crossover that rolls off its response above 200Hz, using a simple 6dB slope, with additional crossover points at 400Hz (12dB/octave) and 800Hz (18dB/octave)—an approach intended to produce a smooth transition to the treble. The other midrange driver is crossed over to the tweeter at 3.6kHz, so that it covers about a 5½-octave range. Each midrange driver is in its own sealed subcabinet.
The lower bass is handled by two side-firing 10" Eton woofers, a carbon-fiber honeycomb-cone driver preferred by Peter Gansterer for its high stiffness and speed. Each woofer has its subcabinet, with nonparallel walls, and is vented out the back. The woofers begin crossing over at 50Hz, and are filtered more at 100Hz, and again at 200Hz.
http://www.stereophile.com/floorloudspeakers/296/
