Показано с 1 по 3 из 3
Тема: USB-32 вход для DAC
    Россия, г. Орёл
    По умолчанию USB-32 вход для DAC
    На сайте audio-gd есть информация о USB-32 входе для DAC
    (http://www.audio-gd.com/Pro/dac/USB32/USB32EN.htm). Я плохо соображаю по английски, а из перевода в промте не очень-то и понял, в DAC есть встроенный USB - I2S конвертер или просто улучшенный USB вход? Подскажите специалисты?
    А это текст с сайта:
    "USB-32 is based on the VT1731 chip, the one best USB interface chip in world .
    Support up to 32Bit / 384KHz in OS X , Windows (XP, Vista, Win7 and Win8 both 32 and 64bit ) and Linux .
    The USB-32 have not connect the +5V from computer for the less disturb , so every times power on the computer then power on the DAC if applied USB playback.
    PC drivers download:
    For the products shipping since 14th May. 2013 .
    Download the USB32 V2.0 driver
    Download the USB32 V2.0 driver install guide
    Download the USB32 driver install video
    If the product was shipping before 14th May. 2013 , please contact us and offer the series number for ask the link of the driver download.
    Windows XP, Vista , WIN 7 and Win 8 (32bit and 64bit) must install driver for USB connect .
    The driver must unzip by RAR . Before install the driver , users must connect to the computer USB port and power on the unit , after install the driver , restart the computer is necessary .
    Mac OSX , Linux (MMX) and SPDIF inputs without driver install necessary .
    FYI :
    Recommend player in Windows : Foobar2000 V1.15 with plugs foo_out_ks & foo_out_wasapi
    VT1731 specs :
    http://www.via.com.tw/en/products/au...1731/index.jsp
    The VIA Envy VT1731 is a 2-channel, 32-bit/384KHz audio controller specifically designed to achieve cinema-quality audio recording and playback in high fidelity USB and MIDI system applications. With the advancement to 32-bit, 384 kHz support more points along the sound wave are recorded and saved, creating the most authentic listening experience when it is converted into analog sound during playback. The VT1731 brings highest audio quality to the prosumer which does not demand a full surround setup.
    The highly integrated single chip USB audio solution is embedded with a number of crucial modules, including a standard 8032 MCU core, USB Transceiver, two I2C master and one slave controller, an I2S controller, a serial flash controller, an SPI port, phase-locked loop (PLLs) with internal oscillator, and a 3.3 V~ 2.0 V regulator.
    The VT1731 also supports multi-channel PCM digital audio format up to 32-bit resolution and 384 kHz sample rate as well as multiple audio bit streams of up to 2 Input Streams and 2 Output Streams. Additionally, the I2S interface of the VT1731 is capable of supporting various customized configurations. An S/PDIF interface with one stereo output port and one stereo input port also supports up to a 24-bit resolution and 192 kHz sample rate.
    Feature Highlights
    USB Interface
    USB 2.0 High-Speed (480 Mbps) Device Compliant
    USB 2.0 Full-Speed (12 Mbps) Device Compliant
    USB 2.0 High-Speed PHY Integrated
    USB Audio Class v1.0/ v2.0 Device Compliant
    USB Device Firmware Upgrade v1.1 Compliant
    High Resolution, Multi-Channel PCM Audio Bit Streams
    Up to 32-bit, 384kHz sample rate
    Up to 2 Input Streams and 2 Output Streams
    I2S Audio Interface
    2 I2S Input
    2 I2S Output
    Mono/ 2-Ch
    16/20/24-bit/32-bit
    32 / 44.1 / 48 / 88.2 / 96 / 176.4 / 192 / 352 / 384 kHz
    S/PDIF Interface
    1 Stereo SPDIF Output
    1 Stereo SPDIF Input
    Mono / 2-Ch
    16 / 20 / 24-bit
    SPIDIF In: 32 / 44.1 / 48 / 88.2 / 96 kHz
    SPIDIF Out: 44.1 / 48 / 88.2 / 96 / 192 kHz
    Blu-ray Disc™ Audio Content Protection
    32-bit/192kHz audio output delivering cinema-level audio experience
    MIDI Interface
    One Dedicated MPU-401 Compatible UART, with Micro-controller Interface Support".
    Завсегдатай Аватар для Alex-master
    из Сумеречной зоны
    По умолчанию Re: USB-32 вход для DAC
    Канцлер, купи Bolero:
    https://forum.vegalab.ru/showthread....дуль-индикации
    https://forum.vegalab.ru/showthread....осах-и-ответах
    и дешевле, и мозги сушить не будешь...
    У каждой задачи всегда более одного решения!
    Россия, г. Орёл
    Спасибо, совет хороший. Я сам присматривался к Bolero, но планирую еще взять DAC от audio-gd и если там это уже все решено, то Bolero будет для меня уже лишним.
